Where to buy Nitriging wok pan?
The_King
Where you all buy Nitriging wok pan? amazon.sg got some made in japan japanese brand Nitriging wok pan
What about TB? any trust one that use real iron instead of cutting corner?
update:
temple street all is round bottom wok. but wok is cheap 18 to 36 (qua look lousy or 3.5 of 10 point)
i know why carbon steel wok so many color, like silver, black, grey, blueish:
grey usually is nitriging
black, blueish is pre season/ heat treated (oxidized) wok, no need to burn coating off wok, just need to do soap wash(when first use) then build on top of the factory preseason. how factory build no one will know
silver is raw metal color, mean need to use wash, burn off the coating then season
and to add, it if doesn't come in a silvery-gray color, it mean it's already been processed or treated in some way (black, blueish wok ).
processed or treated can heat treated, Polished, oxidized it (aka heat treatment to create a protective oxide layer before seasoning)
deathan9el
Honorary Mentor
the stuffs u always talked about quite satki horr ..
not for any average peeps :o
The_King
first time heard of this nitriging
in short it make cast iron and carbon steel rust free as nitriding hardens the surface of the iron or steel. This process creates a surface that is highly resistant to rust and damage,
tanahgu
i have taobao 陆川铁人
the nitrigan coating prevents a seasoned coating from forming like carbon steel
if u cook tomatos n never clean within an hour, will still see lotsa rust
zueinder
why don't search on amazon.jp? I just did a quick glance, think there got a few options and can ship to Singapore.
The_King
i have taobao 陆川铁人
what do you mean?
nitrigan is make the surface harder and rust resist
randyap
I use gourmet brand. Been using their nitrogen cast iron wok for more than 3 years. No regrets.
The_King
la gourmet Quality how? i ask around and their online review their Quality like so so
how the handle like kena water or shaking and rivet? still soild?
your handle is ear type or long handle type?
randyap
No shaking at all after these years of using. Mine is riveted. My whole family using this brand for wok.
The_King
is your handle is ear type or long handle type?
i like this .
their 3 rivet deisgn but the flat bottom for induction is smaller say 5inch vs those in OG or tang is 8inch
The_King
i think no choice to get cook pal by Yoshikawa or la gourmet
TB one i scare they cut corner (like mixing iron with some other old metal of unknow source )
randyap
Mine is this. People always say carbon steel better but I think cast iron more suitable for home use because our burner is not strong. Cast iron can retain more heat first so when u start putting in your ingredients, the wok can hold the temperature.
