- Sep 16, 2018
My Singtel 1Gbps contract just ended.
Tried applied online previously for 5Gbps @ $29.90 but rejected.
Contacted them a few times through WhatsApp but also unable to offer me even the 3Gbps @ $39.90. Keep saying if I never received the promotion they can't offer me the promotion.....
Anyone know what are my available option if I want to switch camp but keep my home digital line (as my parents using)? Am I able to port my home number to other provider?
This has been asked multiple times, yes you can port Singtel Digital Voice number to M1 (free) or Starhub (S$2.14 per month). You have to decide which one to go and then work with the two ISPs to get it done.
As of now, M1 6Gbps offer with free Archer BE805 is probably the best one to go if it is available in your area. Must sign up in the M1 stores, new home offer at S$34.90 per month, switching offer (your case) is at S$35.90 per month. If you are keen, you can go to your preferred M1 store, they will be able to advice what you need to do to port in the Singtel Digital Voice number to M1. Take note the offer is only available in store, not online. And in any case, it is better to sign in store if you need to port in Digital Voice.
More about digital voice porting.
https://forums.hardwarezone.com.sg/...comparison-latest-promo-deals.6665380/page-82
Read the first page of this thread and comes to your own decision.
If you are okay to leave Singtel, as of now, M1 6Gbps new user offer at S$35.90 per month with free Archer BE805 may be a good one. Digital voice is free for M1.
If your line is a Singtel Digital Voice Line, then it is possible to migrate to M1 (free) or Starhub (not free, S$2.14 per month). It is a bit troublesome though as you need to debundle the digital voice from the Fibre Internet. M1/Singtel will be able to advice.
If your line is an analog line, then you can keep using it even after switching to M1 or Singtel.
If you go with Singtel, then the new HB611-SGST or HB810 (more expensive) is better than the older Singtel wireless routers.
More for analog land line: not applicable in your case, but may be applicable for others.
land line can be converted to digital line and bundled with the fibre broadband as long as both are under the same account holder. If the land line account is under one of your parent and the broadband is your account, then you will either need to transfer the land line to you or your parent sign up for the new broadband under his/her account and then convert the land line to digital line.
this was what i did some years back to transfer an analogue land line over to me so i could then sign up for singtel fibre broadband and retain the same number under digital voice.
