Is 9800X3D overkill for 5070TI?
GotBetrayed
Overcpupower but i will buy it.at most point, 7800x3d first gen users also will want a 9800x3d since the chase for fps neverending.
Give your monitor if is aw, should.
Yeah but is actually just sub gaming pc to park at my dad’s house and grandma’s house.
kappak
U also can downgrade cpu to 9700x and upgrade gpu to 5080 since u r on 4k gaming.
Dlss4 is the best the base the better the multiply.
GeForce
AS quoted me top up price from 7800X3D to 9800X3D is $220, what you guys think??
I would say go for the latter should your budget allow. It's a substantial enough performance uplift despite being just 1 generation apart. End of the day.. your wallet decides hahah.
Yongkit
Ram also impt for generating assets when moving in left and right in COD for asset gen of enemys
he can use 1440p resolution on the 4k monitor also if needed more fps.
As for x3d cpu ram is not a critical honestly in cod
GotBetrayed
Gaming is 4K dlss4, maybe frame gen too. Not sure if these 2 CPUs got real diff at 4K or not
MangoCAT
So you should know metadata files are from.... Steam do check ram integrity.
MangoCAT
is ok but pure 4k experience. He say using dlss4 so not my forte for that.
MangoCAT
You are referring to ram speed or capacity?
Ram integrity, then using GPU ram to gen the online enemy. Often a time, offlan mode also go thru the same process.
CPU preload the map and players le
Yongkit
That seems to be quite broad on your statement covered the overall system integrity. Nowadays cod not only available in steam. It also in game pass and battle.net
MangoCAT
oh really ah. if u play nba2k before, u should know they have own server which is essential basics.
86technie
I using g502 X lightspeed, keyboard is G915 TKL, speakers use KEF LSX II and KC62 subwoofer.
Second setup same, only speakers are Sonos Beam 2 and Sonos sub 3 + 2x Sonos ones as surrounds.
Mouse pad wise? Logitech mouse pad got hard and cloth surface.
Both affect the mouse traction so if you haven't got one.
Can try one.
GotBetrayed
Can try one.
I got Logitech power play with the soft surface. Don’t like hard
GotBetrayed
Seems like future games may need more cpu power? Like future cod games etc.
