Dyson PencilVac Fluffycones™
Money no have
tis is on one of my case tat came to me on a v15... :s22: alot owners juz duno wat they getting themselves into.. but with regular maintainance its possible to keep these problems away...
I dont understand.
you mean this is 2nd hand unit? Or you bought brand new
AnTzX_
I dont understand.
i m doing regular servicing for ppl... tis is not a 2nd hand unit which a customer of mine send to me... esp those will pets will have build up like tis which will end up choking the machine, after sometime maybe 1year or so? of using and even spoil their machine.. i had seen countless for my 6 7yrs running tis small side hustle of mine till now :o
esp v12 cos silmmer body always plagued with these kinda situations...
couch.potato
Dyson is not designed in a way that can be cleaned properly easily… :( angmoh design always like that, very good to use but never think of cleaning. Only MIJ then got think of normal people maintenance usually…
zueinder
Still on my basic handheld. The run time and battery management would be key. My current old model had the battery fried because there's just zero battery management electronics so it got overcharged and fried the battery on our first run.
AnTzX_
tats y i make tis into a biz... can help ppl with their problems too:o
couch.potato
Moi just changed to MIJ vacuum, everything just take out to rinse very lihai. But of course suction lose to dyson. But now got robot vacuum, handheld only need to be 7/10. Cheaper also.
robot vacuum u got clean? But now all no tangle easier to maintain alre
AnTzX_
ic actually to each on its on some ppl will go for cheaper ones as if anything were to happen they can juz throw no heart pain... anyway i only focus on dyson vacumm mainly n some other dyson items so for robots i dun really do but honestly with now all the self cleaning station ard its very less to have any issue on the dust buildup on the inside. :o juz more of technical issues...
Money no have
How is this different from omni glide?
Velton
华强北 as its best... anyway for the hair dryer can buy the 1:1 copy... basically excludes the brand only saves u alot... everything else is the same... :o
I bought my hairdryer there.. cheap cheap and AAA grade. Very good too!
daniel_83
wah lao these people use their vac in a construction site la
daniel_83
robot vacuum way better
hands free
dyson dun dare to go challenge roborock
robot alone not enough la
i still use a dyson for de-dusting surfaces (table, windows etc) and the occasional dusty spills/mess
and robot mopping is not good enough too
u will need a wet vacuum
articland05
for me robot can cover 90% of the key areas liao...the other 10% I can just ignore them and live with it :o
nethdale
Hi and sorry to hijack this thread, which robot is good. My Xiaomi robot is showing sign to breakdown. Thanks in advance.
