Yes. No more cheapGrab there and back then buy many things
If you had went to shopee to buy and eaten at your local czechar price overall spent will be similar and you can rest at home
You must be a disgruntled local merchant or landlord.Grab there and back then buy many things
For example you buy A cheap 5buck. Buy B cheap 5 buck. Then you spend it on dragon I or on useless item C which you won't buy if you on shopee
Another way of looking at things. I usually change 1k ringgit to buy things in jb. At the end I left some money. But if I had stayed in sg and went a buffet I would only had spend 70-80sgd max
Waiting for eastern railway to open, can go the other side. Even more chipperjaybee nao sexpensive. i go skudai, ,melaka and kl![]()
Probably because they use fresh chicken in Malaysia while Sg KFC uses frozen chickenHonestly the KFC in Malaysia taste way better since the 90s...
I know it doesn't make sense but
I also don't understand why unless the chicken
they used is local produce while Singapore's
comes from USA or some countries other than Malaysia.
east coast means kelantan? muslim state cannot anyhow hanky panky so will be boring?Waiting for eastern railway to open, can go the other side. Even more chipper
Paying for 300sgd and 300RM might be same price for u but there a difference.If you know where are local residence area. Buying grocery, supplement and especially medication is a lot cheaper there.
if u go to the typical place that Sinkie go then it’s just slightly cheaper or the same price…
More restrictions more exciting?east coast means kelantan? muslim state cannot anyhow hanky panky so will be boring?![]()
Maybe will put into those pig cagewait caught piak piak minah will have to chop kkj?![]()
That what I trying to say. You put it better for meJB is not cheap if it tempts u successfully to overspend. For example, u buy things that u normally wont. Another example is u overeat.
If you only drink teh bing in Singapore coffeeshop but go JB u go buy Changee. Yes, Changee is cheaper in Msia but cannot be cheaper than teh bing in Singapore coffeeshop.
But if you go there to buy your necessities and eat normal meals in their coffeeshops, then it is cheaper and can save alot.
Ish bolehland KFC still the original size and flavour or becum no standard like here one?You don't waste time comparing to zichar. Compare to dtf. That's why I find it strange edmwers went to JB to eat A&W and KFC...
I think its too tiring, even after cheap massage, u stuck at the customs, lagi tired again. Things are no longer cheap in jb malls.If you know where are local residence area. Buying grocery, supplement and especially medication is a lot cheaper there.
i go there to eat foods i cannot afford to pay in singaporeJB is not cheap if it tempts u successfully to overspend. For example, u buy things that u normally wont. Another example is u overeat.
that's huai i go further north naoI think its too tiring, even after cheap massage, u stuck at the customs, lagi tired again. Things are no longer cheap in jb malls.
steel got standardIsh bolehland KFC still the original size and flavour or becum no standard like here one?
i everyday eat this here. you steel sexpect me to eat the same after taking the trouble to cross the causeway?
