Any recommendations?Read somewhere, ppl complaining noisy.
Not sure how true.
I mean those portable without trucking.. just pour water inside..something like thatbut the trunking big problem reh.
Not sure how true.
Not everyone can afford to install multiple aircon units. Sometimes, the other rooms already have aircon, and it is just one specific room that does not. Instead of replacing the entire system just to add cooling to that one room, people might opt for a portable unit.For the umpteenth times, get a proper system 4 split air con. All these portable or casement Aircons are just bad.
TS, maybe you can consider EuropAce brand which they are having offer at $300+ for the portable AC currently.Anyone buy from online?
A cheap one?
Yes it is ok cos also switch on the fan too.my sis has one in one of her rooms but it were made cooler b'cuz the room has a ceiling fan as well
if both turned on, it's as good as an AC
on its own ..
but a portable AC may not be as strong as how u feel/try at the display store (it's helped by the store's very own AC surroundings)
How come you so poor thing?Not everyone can afford to install multiple aircon units. Sometimes, the other rooms already have aircon, and it is just one specific room that does not. Instead of replacing the entire system just to add cooling to that one room, people might opt for a portable unit.
In my case, the other rooms have aircon, but mine does not as Im staying in a utility room, and there’s not even space for a portable unit.
Wow $320 is too expensive.TS, maybe you can consider EuropAce brand which they are having offer at $300+ for the portable AC currently.
https://s.shopee.sg/2fzPOjnQFd
Any recommendations?Just use air cooler lah. Fan with water mist kind. Cheapest.
not sure which brand my sis currently usingYes it is ok cos also switch on the fan too.
