Recommendation for portable Air Cooler ..
jeffprobst
Go to those with shop fronts in Yishun industrial factories areas... May not be cheaper but the way they handled things is what I preferred.
family want use climate voucher. but i guess will check around, probably can get 3 units but 1 unit lesser power since room smaller.
biting
https://sg.shp.ee/qqB2Rwe
Can consider this type of company rather than courts as they are cheaper. I have bought an air con from them and they are ok. You might want to check out other installers on shopee or lazada also
Lchlch
cheap probably go for Europace.
most important is you make provision for hot exhaust air, you can't ignore this if you needed the cool air.
Exactly, that's why I wanted to get one without those tube blowing out hot exhausted air.
jeffprobst
I dnt like window type cos window cannot open anymore
if you got options then good. if you dont have options, then people give you how much advice also like that. you fixated on getting those portable cooler?
helloicanseeu
Most doesn't give you the proper comfort simply because of our humid weather.
Although, there are some new technology coming up.... so you have to research, be the guinea pig, then report here back... hehe
portable ac > nothin i suppose
TS can buy 2nd hand carousell and try if its what he wants
BBClone
It’s honestly better than nothing, those portable water cooler fans
