Health checkup results.
lls0101
Any other references to what's borderline? because I don't understand the results
LDL is higher than optimal. Previously its above 5 mmol/L for many years until I got it down to around 3 mmol/L with diet. Now it's up to 3.5 since I slack on my diet.
AI is excellent to interpret health data. Here is what I copy and paste with my readings.
Your Lipid Panel
Lipid Type Your Value (mmol/L) Ideal Range (General Guidelines) Comment
LDL (bad) 3.57 < 3.4 (optimal), 3.4–4.1 (borderline) ⚠️ Borderline high
HDL (good) 1.77 > 1.0 (men), > 1.3 (women) ✅ Very good
Triglycerides 0.67 < 1.7 ✅ Excellent
Total Cholesterol 5.64 < 5.2 (ideal), 5.2–6.2 (borderline) ⚠️ Borderline high
🩺 Interpretation
LDL 3.57 mmol/L
This is slightly above optimal but not alarmingly high.
If you have no risk factors (like smoking, diabetes, hypertension, family history), this may be acceptable.
If you do have risks, aim for LDL < 2.6 or even < 1.8 (for high-risk patients).
DigDub
No liver function test? Very important also.
Normal also. :o
DigDub
usually this are included. its very impt to check liver function if on such medication.
Yes usually will check for kidney and liver function cos some heart medication will affect kidney and liver.
1982-1994
Your Lipid Panel
🩺 Interpretation
LDL 3.57 mmol/L
Oh ya I could have used ChatGPT to convert the readings, never thought of that, thanks
Checkyrmed
Your Lipid Panel
🩺 Interpretation
LDL 3.57 mmol/L
Particle size, pattern a or b and, most critically, oxidized cholesterol and Lp(a) are what truly matter.
LDL alone means nothing.
lls0101
Did Apo B and Apo A1 too. Looks normal.
But a lower LDL is always welcome.
Checkyrmed
NMR LipoProfile (Nuclear Magnetic Resonance LipoProfile) is a widely recognized test that directly measures the number and size of lipoprotein particles, including LDL, HDL, and VLDL. It provides a detailed breakdown of LDL particle subclasses, allowing for the identification of predominant pattern A or B
Sauron
Angiogram need to insert the thingy into artery via wrist or groin area. Invasive procedure. No emergency case or high risk factors, where got chin chai go n do one.
Also for heart patient with blocked arteries, the LDL should be below 1
