Paracetamol can cure flu?
ricohflex
Bring down fever.
Doctor say ....Take 2 Panadol.....
Here's your MC... That will be $80 please for consultation and medication....
Checkyrmed
Your “prevention” vs cure
U can’t tell the difference
U r confused (or trying to market your product in the dark)
As said, it is not a drug. That is why it works. It helps stop the virus before it starts and helps the body fight it off when it comes.
Checkyrmed
Claimed not to be a medication but can cure virus/flu?
Dunno what weed you smoking?!
It isn’t recognized as a drug by the healthcare industry simply because it isn’t patentable or profitable, not because it lacks efficacy. If you understood how the healthcare industry operates, you would realize that.
Scp173
Mine is funny alway start flu with runny nose den after i tak flu med, runny nose will be cured BUT it will turn into blocked nose, in total my whole nose sickness usually last 3-5 days b4 it auto recover
Checkyrmed
U can get generic brand of clarityn pills from mustafa at just $3+ for 10 tab
Clarityn is too overpriced, dont get chop by them
Medications only alleviate symptoms rather than addressing the underlying cause of the illness. True prevention and lasting resolution require therapies that target the root pathology.
hhab6ch
No. Panadol suppresses the pain receptors as well as fever. However the panadol with cold and flu etc do have additional stuff to help with other symptoms such as running nose and even cough. But all these just help to supress the symptoms for your body to heal itself which is usually the case.
The only meds i believe that can help fight the virus is anti biotics. But we don't prescribe them as much because there's a chance the virus becomes immune to it and you have to move to a stronger one
Btw I'm not a medical professional so i can be wrong
Use mouth wash early enough, you can cure almost all flu or flu-like diseases. Doctors used to give stuff like this. I think some are still giving. The problem is, doctors give it only when a patient comes. A patient comes only when he/she is very sick. When you are already very sick, this has very limited impact. Just 1 or 2 sneezes, you will need to use it. Cures almost all.
This most likely kills whatever virus/bacteria in the upper respiratory system or near the throat.
To achieve good results, need to drink lot's of water too. But purely drinking water has very little benefit.
lalalalalala
is this like betadine?
Checkyrmed
No wonder u kept talking abt omega 6
Omega-6 is a metabolic rate killer and produces numerous pro-inflammatory biomarkers, turned many Andy Laus into BBFA.
Excessive intake drives chronic low-grade inflammation via overproduction of eicosanoids, accelerates LDL oxidation and atherosclerosis which raises the risk of heart disease and stroke, is linked to higher rates of certain cancers through enhanced cell proliferation and inflammatory signaling, worsens insulin resistance and visceral fat accumulation contributing to metabolic syndrome, and promotes clot-forming eicosanoids that heighten thrombosis risk. Did you ever look into this before you post this or even check your omega 6 to omega 3 ratio?
hhab6ch
Yes.
Just that povidone iodine seems to have stronger side effects. I used it during the entire pandemic. Cured virtually all covid symptoms, when there was no vaccine. But had to switch to this due to side effects (may be because of the iodine).
Anyway, some betadine does not contain povidone iodine.
qhong61
Not interested in new product
