As said, it is not a drug. That is why it works. It helps stop the virus before it starts and helps the body fight it off when it comes.Your “prevention” vs cure
U can’t tell the difference
U r confused (or trying to market your product in the dark)
It isn’t recognized as a drug by the healthcare industry simply because it isn’t patentable or profitable, not because it lacks efficacy. If you understood how the healthcare industry operates, you would realize that.Claimed not to be a medication but can cure virus/flu?
Dunno what weed you smoking?!
Try antihistamines pills like Clarityn.
Medications only alleviate symptoms rather than addressing the underlying cause of the illness. True prevention and lasting resolution require therapies that target the root pathology.U can get generic brand of clarityn pills from mustafa at just $3+ for 10 tab
Clarityn is too overpriced, dont get chop by them
Is it true u trying to market ur products?As said, it is not a drug. That is why it works. It helps stop the virus before it starts and helps the body fight it off when it comes.
pls stop your MLM here. reportedThere may be plans to develop this into a product. Please send me a private message if anyone is interested in joining this venture.
MLM? If this eventually goes to market, it will not be sold as an MLM product, as there is no need for doing that.pls stop your MLM here. reported
No wonder u kept talking abt omega 6MLM? If this eventually goes to market, it will not be sold as an MLM product, as there is no need for doing that.
No. Panadol suppresses the pain receptors as well as fever. However the panadol with cold and flu etc do have additional stuff to help with other symptoms such as running nose and even cough. But all these just help to supress the symptoms for your body to heal itself which is usually the case.
The only meds i believe that can help fight the virus is anti biotics. But we don't prescribe them as much because there's a chance the virus becomes immune to it and you have to move to a stronger one
Btw I'm not a medical professional so i can be wrong
is this like betadine?Use mouth wash early enough, you can cure almost all flu or flu-like diseases. Doctors used to give stuff like this. I think some are still giving. The problem is, doctors give it only when a patient comes. A patient comes only when he/she is very sick. When you are already very sick, this has very limited impact. Just 1 or 2 sneezes, you will need to use it. Cures almost all.
This most likely kills whatever virus/bacteria in the upper respiratory system or near the throat.
To achieve good results, need to drink lot's of water too. But purely drinking water has very little benefit.
Omega-6 is a metabolic rate killer and produces numerous pro-inflammatory biomarkers, turned many Andy Laus into BBFA.No wonder u kept talking abt omega 6
Not interested in new productOmega-6 is a metabolic rate killer and produces numerous pro-inflammatory biomarkers, turned many Andy Laus into BBFA.
Excessive intake drives chronic low-grade inflammation via overproduction of eicosanoids, accelerates LDL oxidation and atherosclerosis which raises the risk of heart disease and stroke, is linked to higher rates of certain cancers through enhanced cell proliferation and inflammatory signaling, worsens insulin resistance and visceral fat accumulation contributing to metabolic syndrome, and promotes clot-forming eicosanoids that heighten thrombosis risk. Did you ever look into this before you post this or even check your omega 6 to omega 3 ratio?
