I almost died just now...
deathan9el
Honorary Mentor
are all buildings like this?
the ones unaware would surely be panicking if the doors are locked from the outside, not knowing where to go
had the basement exit was locked as well, then dunno how already
Can Or Not
entered a building, the lift too slow
so went via the fire exit door, pushed open the door and wanted to take the stairs
the door slammed shut and after that I realised the ***** door is locked, I cant exit from insai
I ran up a few floors and down a few floors all the ***** doors were locked, I can't pushed open from insai
A flood of memories rushed thru my mind, I recall the Hilton groom incident
All of a sudden, a stroke of genius hit, I ran down all the way to basement 1 and realize the door was left slightly opened
I breathed easy... and pushed opened the door to escape
So next time beware of stairs ok?
Not.banned.yet
Btw on a serious note. My block has a “locked level 2”. Lift can’t access, door to stairs is also locked at lvl2
but one time I accidentally found a hack to make the lift open at level 2. I went out to explore.
then I realise. Siao Liao. I can’t get the lift to open at lvl2 from the outside of lift. I tot of getting off by jumping. One lvl only, at most broken bone right?
luckily my mind became rational again. I call EMSU. Who then took 1h to arrive. He almost walk away, until I saw him and yelled at him
Full_Cream_Milk
Wa. I kena this before also.
Have to go down all the way then the 1st floor door can open.
The fire exit door can only be accessed from the outside. Likely an accessed controlled building like condo or office. The only door you can exit from is level 1 or below where no access control is needed.
So in such case,
Must always remember the first floor door is openable?
Ethan_
Erm, fire exit not able to exit, or maybe it just meant to be ground level exit? If so, like many ignorance about such. :s22:
shodan99
There is a little white box on the wall where you can smash the glass to release the door. But will also activate fire alarm.
Jeremy1
Even if all doors are locked, you still can wait till day when someone from outside unlock the door.
Nothing is going to happen to you.
mel1888
b
bruh dun need stroke of genius to know alot office buildings are one way
