Blitzzzz
- May 26, 2002
invader only realistically offers an upgrade of the mobo, but the bar is on the floor with aftershocks offering. psu seems like similar if not identical model, case is subjective.
for 1.3k, ur looking at 5060ti builds. intel builds with that gpu tend to be more pricey around 1.4, though i dont think ryzen is far behind nowadays for 3d work. do remember to get the 16gb version of the 5060ti.
I think I can do a little better than the floor if that is what Aftershock is like.
I've been looking through invader's list and following @abstrax's advice on budgeting, the below 2 setups are what I've shortlisted to fit within my lower budget of 1.3k+. I have opted to change the PSU (based on SPL's PSU Tier List) to go from "E Tier" to "B Tier".
Any advice on further slight changes to be made? Are there any glaring parts which are as terrible as that particular "aftershock gigabyte mobo" and the "E Tier PSU" that I have missed out?
IM5060TI7600-M20-YF20
SGD $1,333.00
AMD RYZEN 5 7600 3.8GHz 6CORE/12THREADMSI B850M GAMING PLUS WiFi MOTHERBOARD
THERMALRIGHT ASSASSIN X 120 R SE ARGB WHITE
CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36
ASUS PRIME GeForce RTX™ 5060TI 16G GRAPHIC CARD
BIWIN NV7200 1TB 7200MB/s PCIe GEN4 NVMe M.2 SSD
SILVERSTONE ET650-B 650W 80+ BRONZE PSU (Changed to SILVERSTONE TRITON 750W GOLD ATX3.1 PCIe5 for +$33)
SILVERSTONE LD04 BLACK ARGB TEMPERED GLASS
3 X 120MM ARGB FANS
HIGH SPEED AX WIRELESS AND BT | WIFI 7 + BT 5.4
WINDOWS 11 HOME UN-ACTIVATED
IM5060245KF-M13-YF13
SGD $1,348.00
INTEL CORE ULTRA 5-245KF PROCESSORASUS PRIME B860M-A WIFI CSM
MSI GeForce RTX™ 5060 8G VENTUS 2X OC
3 X 120MM ARGB FANS
HIGH-SPEED AX WIRELESS AND BT | WIFI 7* + BT 5.4*
), overall "only" around 7k and way better than what aftershock offers. i dont even know if this is worth paying almost double vs a 5080 pc though.
