Computeron
- Mar 22, 2005
wanted to hoot this too... but old tech liao.
so decided to give a miss n get F7
I'm using one foldable for literally everything... So the processing power also plays a part in my decision making hais ..right now i dun think theres a perfect phone that does all at once, even though Honor is close, but bragging about being the slimmest when the bump so big kinds of defeat the marketing. But also comes down to what factor is the deciding factor for each person. For me, the deciding factor is the bigger screens, not as picky for cameras so long as its decent enough can already. And the 7core SD8Elite tbh is not a big problem when the core they disabled is the lower clocked M core, not the 4.3Ghz one
Agree.Actually i feel the N3 camera is very good. Still beat all the new foldables from Honor and Samsung. Is V5 using the same tele lens as N3?
i have N5 and OP13 so i can pretty much say the difference isnt too much missing that 1 lower clocked core. 7C Elite is still faster than the 8G3 that vivo decided to use backI'm using one foldable for literally everything... So the processing power also plays a part in my decision making hais ..
Do you do any video editing on your N5?? That's also one thing that I do quite often...i have N5 and OP13 so i can pretty much say the difference isnt too much missing that 1 lower clocked core. 7C Elite is still faster than the 8G3 that vivo decided to use back
not to that extent, but if N3 is doing fine i dun think it differs that much tbh, esp on foldables with no active cooling. Even my redmagic 10 Pro with active cooling cannot keep up the clock stability % in 3dmark stress testDo you do any video editing on your N5?? That's also one thing that I do quite often...
8 gen 2 processor a bit dated le... Kinda struggling to keep up with my multitasking recently haha..not to that extent, but if N3 is doing fine i dun think it differs that much tbh, esp on foldables with no active cooling. Even my redmagic 10 Pro with active cooling cannot keep up the clock stability % in 3dmark stress test
My N5 SOT still 6 hours +- with 30%-35% left. I don't play game. Just WhatsApp + Rednotes + FB and others like banking apps, stock apps etc. Rednotes took around 40% of total usage...My N5 SOT only 4 hours plus battery left 38%. Quite disappointed. Review say can get up to 10 hours. Only watch Netflix for 2 hours. Something wrong?
Not even using the inner screen throughout
Oh. Mine my SOT usually 4-5hours but standby is around 1d 5-6hours with 25-30% left.My N5 SOT still 6 hours +- with 30%-35% left. I don't play game. Just WhatsApp + Rednotes + FB and others like banking apps, stock apps etc. Rednotes took around 40% of total usage...
Other than (3) I don't have other issuesAnyone else having these issues with the N5? Overall, I still find it okay, even though the F7 and V5 are super tempting.
(1)The phone randomly restarts while I’m using it — happens like once every 3–4 days.
(2)The font size changes on its own from Small to Standard — usually when I switch from small screen to big screen and then back.
(3)Auto-rotate acts weird — I turn it on, switch to big screen, watch a YouTube video in fullscreen, then when I exit fullscreen, it stops auto-rotating. Even if I manually toggle it, it doesn’t work unless I switch back to small screen or exit YouTube again — then it works fine.
I have not experienced any of the issues you raised.Anyone else having these issues with the N5? Overall, I still find it okay, even though the F7 and V5 are super tempting.
i nv encounter any of the issues you raised, strangeAnyone else having these issues with the N5? Overall, I still find it okay, even though the F7 and V5 are super tempting.
You might want to consider reset all settings then see how?Anyone else having these issues with the N5? Overall, I still find it okay, even though the F7 and V5 are super tempting.
The earpiece is a bit weird. You need to find the right angle to get the speaker directed to your ears. So far my best angle is when the center bottom of the phone is at my nose when I am taking a callOkay i been trying to figure why my 3 days old phone the call volume is very low. Tried adjust to the max but still same problem
Actually speaker volume and bt volume also soft. Lol...Okay i been trying to figure why my 3 days old phone the call volume is very low. Tried adjust to the max but still same problem
This is a soft phone.
not bad ma, if its f7, with the same usage you probably less than 10% liaoMy N5 SOT only 4 hours plus battery left 38%. Quite disappointed. Review say can get up to 10 hours. Only watch Netflix for 2 hours. Something wrong?
