yuri2
- Nov 30, 2002
I supposed I could vacuum. It just seems water contains the dust/dirt better.why dont u vacuum either the inlet or outlet? Faster?
Not sure about color bleach, i have read articles on using vinegar.
When I drill holes in concrete walls, I'd have a damp cloth nearby to catch the dust.
You could use vinegar to clean. It's a weak acid. I use it to dissolve rust on tools. I also have citric acid powder. Generally acid can be used to clean metal. But you need to careful when handling the stronger ones.
Soapy solution may be a safer alternative to clean the aluminium coil, since soap lifts up dirt, and the water carries it away.
I think using a damp cloth with soap solution to slowly clean the blower may be a better idea, rather than blasting it with a jet of water.
