Anybody made Zeiss lens at JB Mid Valley before?
fatscaryuncle
Whuat lens the coating got 2 years warranty ah? Heard Hoya has it ah
Zeiss only 1 year
lycanboy
I made hoya myopia lense for my son.....actually orth-k contact lenses is very effective in controlling myopia. But my son is not ready for it
Is it much cheaper than SG? It's about $550 to $600 in Singapore. o_O
KPO_SAHM
Hoya I did for my youngest son was about $550. So far so good as he is using atropine every night before he zzz and having more than 1.5 hrs of outdoor everyday + weekly badminton lesson + weekly 2 hrs swimming. And not academic driven. Myopia (touch wood) has not been increased for a year.
Previously my other 2 kids had atropine but no outdoor n did more homework at home. That was why myopia was not under controlled.
lycanboy
Ok. Thank you. Doctor prescribed Atropine because of high myopia?
KPO_SAHM
Cause myopia keeps increasing . Atropine is to slow down or stop myopia . Wanted to try orth-k lense ($2k, I think use for 1 or 2 years) but too exp and have to really take care of hygiene
lycanboy
Thank you for sharing!
Emperor_Hippo
ic! berlin frame with the ZEISS Progressie SmartLife Pro Individual 1.74 Index lenses
hmmmm.... then i guess lindberg with zeiss progressive most prob will be thereabout this price liao.
thinking might as well i go paris miki and do... 🤔
testerjp
I bought Rayban + hoya.
Frame one for one
One set has hoya lense
RM1029
Bought from seen at JBCC no need to go mid valley :(
If want to do in Singapore and want cheap, can consider pentax lens. It's the sister brand of hoya and uses the same coat. I don't feel any difference.
nethdale
Anyone hooted lindberg + zeiss in JB before?
I'm a fan of Lindberg and always on the lookout for good deals. Which series are you looking for? If it's the Horn series, it's only available at Mid Valley, but very limited selections. Other series like n.o.w and Acetanium can also be found there, though the variety is quite limited. Berlian at KSL may not carry much, and I haven’t seen any Lindberg frames in City Square optical shops.
