SingTel 3Gbps, 5Gbps & 10 Gbps Enhanced
wwh5210
i saw ur earlier posts liao.. sad lor. i can recon soon. last time recon too early before all these promo, now too late. :( :(
Tell u a public secret, those offers are always valid 24/7 all year round. Just a few clicks by their sales team only. Just give them a call and ask them politely.
The SingTel tech came to install the new ONR and upgrade my 3Gbps plan this morning. Initially I I wish to continue to use my old Asus routers (AX56U and AX58U) unfortunately, it doesn't work no matter how I tried. End up just use their "free" TP link router. The set up was pretty easy, just make sure the cables are connected properly and boot on, the download the TP-Link app to some basic configs then go to go.
My plan is 3Gbps, XGS-PON Optical Network Router + 2 units of Singtel WiFi 7 (TP-Link BE11000) at $39.70/month.
For your Asus, usually you may want to carry out factory reset and then set it up again. You may have to use AP mode in order to avoid Double NAT and to make Asus AImesh Ethernet Backhaul to work.
If you were using ONT, usually your Asus router will have Singtel VLAN profile enabled, that may well be the issue for you. You have to disable Singtel VLAN profile.
On the other hand, it makes sense to use the two HB611-SGST if you want to get faster wired and WiFi speed, as HB611-SGST has 2.5G WAN port and 2.5G LAN port, as well as triband WiFi 7 BE11000.
wwh5210
I did both but still doesn't work (with SingTel profile too). SingTel VLAN profile under ONR settings?
No, disable Singtel VLAN profile in your Asus. Nothing to do with the ONR.
But it is better to carry out factory reset and then set it up in AP mode again. That is usually the way to go.
Kennethzzz
I just re-contracted my broadband to the 3gbps plan. My current setup is ONR with TP-Link HB611-SGST.
After changing, my wifi keep having connection issue intermittently. I also unable to access TP-link router via web browser. Anyone also having the same issue?
sacredrays
chatted with them only managed to get 3gbps mesh at 39.70. 2x hb611 and 120 shopping voucher.
asked them if dw so many router they say no better promo with 1 router currently.
guess i just take it ba. good thing the ubiquiti ucg fibre forever oos in sg so haven't committed to any routing/ wifi 7 ap stuff yet. :ROFLMAO: :ROFLMAO:
What are the devices which are having issues?
What is your old setup before the recontract?
As for the Web GUI, you need to get the IP address of the HB611-SGST (usually configured in AP mode by SingTel, 192.168.1.x) from the SingTel ONR (192.168.1.254).
speedknight
Moderator
Moderator
Now I am thinking if I should invest on a 10G switch and an USB C ethernet adapter×so that I can enjoy full 5gpbs on my computer and also future proofing. But For one it's expensive, For another I very lazy to pull another RJ45 into my room also.
Current setup:
1) ZTE ONR in the living Room <10G - 2.5G> HB611 in my room <2.5G-2.5G>Motherboard
2) ZTE ONR in the living Room <1G - 2.5G> HB611 in my living room.
3) ZTE ONR in the living Room <1G - 1G> Singtel TV setup box
sacredrays
Current setup:
actually ur 2nd mesh router cannot directly connect to the 1st mesh router for 2.5gbe to 2.5gbe ethernet backhaul?
speedknight
Moderator
Moderator
Can. But if I am going to spend the effort I might as well make sure I get Full 5gbe wired and both my wireless will be at 2.5gbe
sacredrays
anyone know if date of installation need to have the contract owner to be around or anyone at home can already? if not around need authorization form or anything? where do i find one?
speedknight
Moderator
Moderator
IIRC you need to be around thats why I was pushing them abit. Because my work anything less then 7 days considered urgent leave... By right they suppose to get back to me in 3 biz days... But 5 days in I don't hear from them. Oddly after I called them, the confirmation came later in the evening 😂🤣
sacredrays
IIRC you need to be around thats why I was pushing them abit. Because my work anything less then 7 days considered urgent leave... By right they suppose to get back to me in 3 biz days... But 5 days in I don't hear from them. Oddly after I called them, the conformation came later in the evening 😂🤣
oh.. so got something to sign during installation is it?
limck
Actually anyone can sign since no verification done. Of cos if there’s issues later on you can’t blame the field engineer if your family member didn’t check properly before signing
Scp173
Got the white tp link router after recontract
Can the old singtel mesh router be use as a mesh (the standee type old mesh router)? How to link?
eedwinn
Hi guys,
How do I change the network name and password (and other settings) for the HB611?
I’ve downloaded the TP Link Tether app but it keeps telling me error. Is that the wrong app to use?
sacredrays
i got 2 hb611 in my network, i enabled fast roaming in the wifi settings on the app but it keeps getting disabled after i power off and on the routers.
any workaround other than don't off it? if not i just heck care and don't enable fast roaming liao.. :(
