If want to look high class/ atas/ all used very good & durable materials, that’s why so expensive..
Now same... Just did mine with flooring... Whole house carpentry... 45k... 4 rm. All people use ID. Cos I find direct contractors.Why nowadays home renovation so expensive? I want to do a simple 4-5 room hdb flat also 80-100k. Not even doing much carpentry.
8 years ago, 35k I can settle the whole renovation for my old flat for similar work done.
The overhead crazy... My house warming my frds said did I spend alot... I say no... They was like what... Now no 100k no talk..Increase 1-2% GST, reno cost will increase from $35k to $80-100k…Sinkies reno tokways are “chop carrot head” world champion.![]()
Yes... Functional... Not house warming type of reno.... I got my first house so I where I should spend money on.this... HDB dont ned ID... unless trying v hard to make it look less like HDB, more like condo.... imo most couples are guilty of it... you see hw hard to try lah... bomb shelter oso want to conceal... wiring oso want to conceal although nt allowed... smart lighting... feature wall... wabi sabi... do all this sure $120k...
my uncle juz renovated his whole hdb flat... his son help him settle... they go with contractor... no ID... juz pick simple theme ... wood and white paint... contractor follow... he do everything only $25k like tt... without appliances....
nowadays cleaners not stupid liao, $300 they wun do such jobs or they will nego price with you.Ask the cleaners downstairs if they got lobang for hacking/drilling of tiles. Should be less than $300 to settle the whole house.
BacksplashYes... Functional... Not house warming type of reno.... I got my first house so I where I should spend money on.
Concrete support for sink area. Now even water leak no issue.
Kitchen top and back wash.. All sintered stones.
Flooring, eproxy grout with polishing. Make the floor look like one piece and easy to clean.
$45k for these?Yes... Functional... Not house warming type of reno.... I got my first house so I where I should spend money on.
That’s why ?
Hack already, where to dispose the construction waste ?
Price have double like 10 years ago..Why nowadays home renovation so expensive? I want to do a simple 4-5 room hdb flat also 80-100k. Not even doing much carpentry.
My bad... 4 pieces 2.4k alr... Both side.Backsplash
Oh I see... I thought people not expensive dont like... No 100k reno meaning no good... Those cannot afford will always doomed next gen or blame ruling party.lol heng you say here instead of elsewherecos other people are paying around 35k tops for bto 4rm with full carpentry, sintered stones, epoxy/microcement flooring and everything else with direct independent contractors
your 45k is already considered expensive liao
npnt.
relative say 40k whole house with carpentry. i went to see.. low quality stuff, edges not rounded, workmanship like crap, cheap laminate, cheap china sintered stone.
Now 80k is consider budget reno by those bigger IDSome set a minimum reno price of $20k and above then they will entertain your project.
