Griggs
- Mar 2, 2008
What happened with jay2centsi am not sure if ur superflower has that connector... if u have then dont need to use the adapter.
just dont be like jay2cents haha
when he tried to run a 5090 with a custom firmware rated at 1000w but in real life its 1600w then his psu went kboom...What happened with jay2cents
Online purchase? Can feedback to the platformJust bought a CPU & Mobo bundle from a major retailer but surprised to see the mobo only comes in a white box that does not have the usual retail packaging / sleeve but has local distributor warranty via invoice...
Wonder if this is a System Builder stock? Any ideas / info share on such mobo sets...?
https://cultists.network/140/psu-tier-list/I have narrowed down to 2 PSU for upgrade, wonder if anyone has any idea which might be abetter choice
LIAN LI EDGE850-850W BLACK ATX3.0 PCIe5.1 80+ PLATINUM
SEASONIC FOCUS GX-750W V4 ATX3.1 PCIe 5.1 80+ GOLD
seasonic: https://www.cybenetics.com/evaluations/psus/2579/I have narrowed down to 2 PSU for upgrade, wonder if anyone has any idea which might be abetter choice
I went to the store... This mobo model stocks are all non-retail packaging...Online purchase? Can feedback to the platform
this setup should be more than enough for ur use case. as deepblue mentioned, maybe all u need is to add another 8gb stick of ram.Was thinking to rebuilt.
Anyone can help or advise any of the parts can reused?
CPU & MB Bundle: AMD Ryzen R5 1600 & Asrock AB350M Pro 4
RAM: Kingston ValueRAM DDR4 2400Mhz 8GB
SSD: Samsung EVO 850 M.2 250GB
Hard Disk: Toshiba 1TB
GPU: Zotac GT1050 TI 4GB GDDR5
PSU: EVGA 700W Bronze
MasterBox Lite 3.1 m-ATX
OS: Windows 10 pro
Will be mainly use for movies or attach to prism TV as well as for work n stock monitoring.
invaders cheapest am5 9070xt offering with the r5 7600 is around 1.6k. im not sure if the 98x3d, aio and better psu are worth almost 1k (>60%) more.A pricing sense check here:
Cosair Vengeance RGB CL30 6000 2x16GB
Thermalright Core Vision 360 ARGB AIO
MSI B850Gaming Plus Wifi
Superflower Leadex VI Platinum Pro 850W
AMD 9800X3D
Sapphire Pulse 9070XT
Total $2,569
things to look out for are radiator, motherboard, psu and gpu compatibility.How to know if these are compatible with my current case?
most likely bulk stock but should be legit. theres a reason why theyre significantly cheaperJust bought a CPU & Mobo bundle from a major retailer but surprised to see the mobo only comes in a white box that does not have the usual retail packaging / sleeve but has local distributor warranty via invoice...
currently i see nzxt c850 gold for also around the same price on laz direct from distro before voucher, so that would be the go to for me. the fsp vita gm 850 is also decent.seasonic: https://www.cybenetics.com/evaluations/psus/2579/
Lian Li: https://www.cybenetics.com/evaluations/psus/2458/
Basically, both are great and u can't go wrong with either. It depends on their physical dimensions and if you don't have any requirements for that (no case constraints), just get the lian li if they are the same price simply because 850w.
Although I would pick Montech CENTURY II 850W instead:
https://www.cybenetics.com/evaluations/psus/2813/
Simply because it's usually the cheapest option and on the same tier as the other 2.
most likely bulk stock but should be legit. theres a reason why theyre significantly cheaper![]()
What u using the PC for?Hi any recommendations for a budget DIY rig (on a budget of 600-700) or would it be better to get from aftershock etc?
what monitor do you plan to use? you can get away with a igpu actually with your usage that means even a beeslink will do.Hi any recommendations for a budget DIY rig (on a budget of 600-700) or would it be better to get from aftershock etc?
Will be using a 1080p monitor. Are the current igpus able to run dota 2 without any fps drops?what monitor do you plan to use? you can get away with a igpu actually with your usage that means even a beeslink will do.
680M should run it without issue since dota 2 is a cpu bound game.Will be using a 1080p monitor. Are the current igpus able to run dota 2 without any fps drops?
without any fps drops i dont think so...Will be using a 1080p monitor. Are the current igpus able to run dota 2 without any fps drops?
if u dunno DIY, buy from AS lorHi any recommendations for a budget DIY rig (on a budget of 600-700) or would it be better to get from aftershock etc?
