Mecisteus
But the hold timing seems off.
I set to 600s hold. But from peaceful or move to none, it takes 14min on all 3 sensors at 3 different locations.
Will try to adjust different hold periods.
I bought this model. Just nice USB C type so can install beside my Smatrul switch with USB C port.
https://s.lazada.sg/s.XPjoU
Confirm something is wrong with the timer.
For every 5min hold, there is like additional 2-3min hold from peaceful to none state.
I think it's just a small bug which can be compensated.
Overall, I see this presence sensor being more powerful than the typical PIR sensor.
Mecisteus
I had bought nearly 40 devices from Smatrul at Shopee.
So far I managed to claim 1x replacement for a defective WH switch under their warranty.
I suspect the switch was damaged during installation by a bunch of noob electricians. The touch screen version has some components behind the face plate.
They even rewire my smart switches wrongly from 2-way switches. 😂
kun1he2
Right now, I have 4 x spoilt Smatrul switches hidden in my ceiling - still haven't figured out what switches to buy next to replace them.
Hesitant to go all-in with HA plus compatible ZB controller like SMLIGHT since it will then become the weakest link.
Right now, the hybrid approach seems to work quite well with local Tuya for HA with HomeKit integration but still able to control everything via Google Home in case anything goes wrong with the HA box (or ZB controller).
hkchew03
I believe coz they are not using Home Assistant and using the native Aqara ecosystem?
Anyway, from what I understand, for Home Assistant to control the ZigBee devices directly, you'll need to deploy a ZigBee coordinator that works with Home Assistant - i.e. Aqara M series hub won't be compatible.
for HA, you just need Zigbee dongle, no other hub required. They are stable enough once you add enough router devices (smart plug, smart socket or even wired presence sensor)
If you are talking about smart module, personally found it not as durable, my only 4 gang smart module failed while other 10+ smart switch is still running.
Reason why people run HA for direct integration is reduce the reliance on online system and also not to deal with multiple ecosystem. HA box or ZB controller failure is just as high as your hub, internet access or even Homekit integration.
merriman
Relays/module? I'm using about half a dozen of zigbee relays bought from Aliexpress (Matseeplus brand or something). Have been rock solid since first bought about 3 years ago. I connect them to HA Yellow by zigbee2mqtt. For zigbee devices, with HA, I like the fact I can use affordable, random no-brand devices or more expensive branded ones. Not locked in into any platform.
Surprisingly, I have close to 15 Shelly branded modules/relays, but have replaced 4 of them throughout this 3 years due to various issues; stuck at on, WiFi connectivity issue or relay unable to toggle with electrical trigger. I would have expected longer lifespan from a branded device...
duhduhduh
Sorry noob question guys.
Assuming i get the aqara switches without aqara hub and using HA only, if there is an intention to set up two way connection (i.e. 1 switch to control light at door, and another 1 switch to control light from the bedside), i understand the solution is to turn 1 of the aqara switch to control the main switch. but correct me - neutral or non-neutral will not make a difference, right?
hkchew03
no diff, just get a scene switch for bedside instead of running wires.
kun1he2
Is this the model that you're using?
https://www.aliexpress.com/item/1005004205732767.html
rza29
Hi experts, I am IT savvy but for home automation, I prefer to look for a local vendor that can hep supply the necessary components with warranty. Went to Orvibo today but their screen is mainly chinese voice control, only 1 model is english voice control. Any local companies to recommend? Gonna do renovation of majority of the house, so wanted to switch to home automation
merriman
By screen, you mean control panel of some sorts mounted on wall?
Curious as to why some prefer this method. Still need to walk to the panel to press. Compared to having a dedicated tablet as dashboard.
hkchew03
and what happen the local vendor close down? Orvibo is probably mainly based on Tuya, so are most smart home company.
rza29
The panel on the wall is stylo la. So if I diy, I have to get a tablet and what apps to use to create a nice interface and compatible with google home?
merriman
Depends on what platform you choose to use? Then just login to whatever app/platform you already chosen in the tablet.
If you savvy and willing to diy and willing to spend some initial setup time, can try out Home Assistant. Can create any kind of interface you wish to. Up to your imagination. And can mix and match devices from all brands.
rza29
Thanks. Will try to do more research. Seems like aqara have a store in shopee but they dont seem to sell the mixpad. I can still purchase it from other sellers and they should work right? I think likely will spend 1.5k for mixpad, lights and switches. Will probaly get those touch screen switches for a few places
Mecisteus
I completed my reno last month. Spent a couple of weeks to look into smart home.
I skipped all local vendors. 2 reasons. They are more expensive and their support may not be for long.
So what platform do you intend to choose ?
I opt for all Tuya related devices. I bought all of them from shopee. I like the customer support. So convenient to request return refund being a platinum member and using Mari related payments.
Now that my smart home is stable, I am considering to explore into HACS and Tuya Local.
Things that I did or bought. Neutral wires on every switch, smart switches including water heater, presence sensors, Tuya hub, T&H sensor, smart relay, smart plugs, smart fans and smart lights.
merriman
Aqara more expensive, but supposedly better hardware quality than tuya based switches. And aqara switches have more features as well.
ZacharyA
I have a few Aqara S1E across the house. Can see time, weather. I only control using the screen if I am within a feet or two. Most of the time I use wireless switches (on the coffee table) or dining table. Or sensors to activate (e.g. upon entering the house) or presence sensors to turn on/off ceiling fan when I am no longer at the dining area / sofa.
abluesnail
Hi home automation lovers! 👋
Saw this thread and thought I’d share a lobang for anyone interested in smart homes. I’m an NUS student doing a study on smart home living in Singapore.
Quick 3–5 min survey, and if selected for a follow-up:
  • Interview: $70 Trip.com vouchers
  • In-home study: $140 Trip.com vouchers
If you’re interested, DM me and I’ll share the survey link. Would really appreciate your input! 🙂
Mecisteus
If cash or supermarket vouchers, I would have invited you. :p
