Yes, my point is that the relay switches are typically electromechanical, which are subject to wear and tear.The click is only sound of relay switching.
I bought the Smatrul non touch version. I don't like the noisy clicking sound of the mechanical button.
I know the mechanical type won't last long. So I bought all touch versions.
I'm not sure of the other smart switches.
But the non touch type has another push button to interface right ?Yes, my point is that the relay switches are typically electromechanical, which are subject to wear and tear.
Curious to know if there are any smart switches in the market which use solid-state relays.
Yea I guess these are called dry contact relays? A mechanical contactor open and close the circuit. All the switches/relays I have used so far are this type(shelly,branded and non branded tuya switches/relays, Aqara).Yes, my point is that the relay switches are typically electromechanical, which are subject to wear and tear.
From my understanding, dry contact is to control a different circuit and doesn't supply power. So cannot replace our light switch.Yea I guess these are called dry contact relays? A mechanical contactor open and close the circuit. All the switches/relays I have used so far are this type(shelly,branded and non branded tuya switches/relays, Aqara).
Already needed to change out quite a few of them due to them being stuck at on.
Will be also keen to learn of other type of switches that doesn't use such mechanism. Similar like a smart bulb achieve on/off?
wow you're a legend in home automation.Been using a mixture of Sonoff, Aqara and Near smart switches for the past 6 - 8 years. Only the "no name" and OEMs died within 2-3 years; the others have been solid.
All my smart lights and switches are on ZigBee, managed and controlled locally by Home Assistant over ZB2MQTT. A stable and reliable ZigBee mesh network requires proper planning and laying out sufficient "in-between routers" to improve network coverage. The coordinator makes a whole lot of difference, too. My current favourite will be the SMlight SLZB-06.
I will recommend sticking to either the Aqara or the Sonoff brand for smart switches.
But I do agree branded names tend to build good quality products because their reputation is at stake. But you have pay a premium price.
I am still a new bird. I prefer to go with value to experiment my journey.![]()
Just realized that HA got a new(?) Tuya Local component that was released mid last year that can co-exist with Cloud-based Tuya... not bad, managed to fix the out-of-sync light status:Btw, noticed that quite a number of the Tuya WiFi switches don't seem to sync their state immediately to HA (not using local tuya).
Weird thing is that when I view the device using the Smart Life app (without changing state), it will immediately show the correct state in HA. So most likely, it is the devices not updating their state to Tuya Cloud - and viewing them forces them to sync to cloud and then to HA.
not new, there has always been 2 Tuya, Local-Tuya and Tuya-Local.Just realized that HA got a new(?) Tuya Local component that was released mid last year that can co-exist with Cloud-based Tuya... not bad, managed to fix the out-of-sync light status:
https://github.com/make-all/tuya-local
Depends on the devices, does it require additional press of power button etc after switch on? if not WIFI smart plug is probably the easiest and cheapest option.Hi guys, I just want to automate some stuff like schedule timings to turn on and off home devices.
Is buying Smart Plugs the easiest way or is there a better way to do it?
TIA![]()
I can set it to on beforehand so that's fine.Depends on the devices, does it require additional press of power button etc after switch on? if not WIFI smart plug is probably the easiest and cheapest option.
Depends on the devices to control.Hi guys, I just want to automate some stuff like schedule timings to turn on and off home devices.
TIA![]()
Yeah smart plugs will do, Tuya ones I guess unless you guys have other recommendations.Depends on the devices to control.
If fan and lights, then you need smart switches
If ac socket appliances, then use smart plugs.
The 16A is enough.Yeah smart plugs will do, Tuya ones I guess unless you guys have other recommendations.
Does 16A or 20A matters if it's for things like electric kettle or dehumidifier? Most default wall sockets are 13A right?
I see, what made you go for Smatrul?The 16A is enough.
I am also new to smart home.
Gotten all the Smatrul products from shopee. ie sensors, switches, plugs, zigbee.
I have been using for 2-3 months. So far so good.
TIA![]()
IMHO Smatrul is like Xiaomi and Huawei when they began. Not many dare to try them when they started. Now they already grow bigger.I see, what made you go for Smatrul?
On a side note, Taobao also can buy Tuya smart plugs, looks the same to me.
