What's the price though?There was a mini sale on Aliexpress last week, pulled the trigger on iplay70 mini ultra
US $285.46What's the price though?
It's the chipset I guess... probably more expensive with cellular... they've to cut some corners to get the price down... even now the Pro is pretty expensive...Such a shame the Ultra has not cellular
Thanks for the reviews bro! They're good... much more comprehensive than the well known international writers or YouTube channels...My text review is up
https://www.parkablogs.com/content/alldocube-iplay-70-mini-ultra-review
In short, really good tablet. Huge upgrade over the iPlay 60 mini Turbo. Whether to spend the USD 100 more to get the better tablet comes down to how much you want to spend. But if you spend, I'm sure you will be very satisfied with the user experience.
The tablet looks good, feels good, sounds good enough, is fast.
Downsides
- No biometric unlock
- No cellular option
- No grid view for task switcher
- Don't expect OS updates
ALLDOCUBE iPlay 70 Mini Pro Tablet 8.4" MediaTek Dimensity MT8791 Tablet Android 15 90Hz High Refresh Rate 1920x1200 Resolution 16GB+256GB+1TB Expansion 6050mAh PD18W Dual Speaker 6-Axis Gyro WiFi 6
https://amzn.asia/d/dO0umyJ
Unavailable
If you need OS updates, then alldocube is not for you. They do have "decent/acceptable" hardware at the $200-$250 mark. FYI, the iplay 70 mini pro has only 1 single speaker.Looking for a cheap but reliable 8 inch tablet as well for Chinese Entertainment apps, no need Google Play, around S$200 to S$250.
I like my previous China version Huawei M5 Lite (M5 青春版) 8 inch tablet bought in 2019, Kirin 710 CPU, 4GB/64GB version with 1920*1080 LCD display. It is now running Harmony OS 2.0 but unfortunately it becomes quite slow, probably due to the 4GB RAM.
Recently I bought a new Huawei Matepad SE 11 Lite tablet 2024 version, 8GB/128GB version, at RMB 1019. Interestingly (or unfortunately) it is still using the Kirin 710 CPU after so many years. And it runs Harmony OS 3.0 (the non Lite version runs Harmony OS 4.0). Thanks to the 8GB RAM it runs rather smoothly. But I feel 11 inch is just too big for my use case.
I bought the iplay 70 mini ultra version instead
do u need 8-inch form factor?Taobao selling the iplay mini 3 ultra with Google (same as mini 70 ultra) for 328$sgd (listed price 1566rmb) all in worth to get? I see aliexpress is abit more expensive if factor in the gst.
