- Sep 16, 2018
Cudy TR3000 Travel Router (AX3000, 2.5G port, 1G port, 128MB Flash, 512MB RAM) OpenWRT test.
1. Impression of the stock firmware -- only tested the web UI for like 10 minutes, not too bad, but no SSH access, so no fun.
2. OpenWRT Setup is rather simple. I also tried to use TFTP64 under Windows to restore the Cudy Stock FW as well.
https://openwrt.org/toh/cudy/tr3000
3. I am testing it as the "wireless adapter" for my Windows laptop, similar to the stock FW's WISP mode.
https://openwrt.org/docs/guide-user/network/wifi/connect_client_wifi
Asus TUF-BE6500 (CH60, 160MHz channel bandwidth) -- wireless, 4m away -- Cudy TR3000 (Ch60 5GHz uplink)
Wireless become the WAN device in this case (wwan).
Both Cudy 2.5G and 1G port become LAN ports in this case (I remove the normal WAN port and add it to the br-lan). br-lan now includes both eth0 and eth1.
In this case, TR3000 still has functions like NAT, DHCP and Firewall.
4. SpeedTest results.
4. 1) wwan speedtest from the TR3000 router itself
4.2) Acer Swift Go 14 laptop wired connection speedtest (WiFi disabled)
TR3000 2.5G LAN --> Acer Swift Go 14 2024 model with Ugreen 2.5G network adapter (wired test)
4.3) Acer Swift Go 14 laptop wireless connection speedtest (close 50cm range to the TR3000). Take note TR3000 is 4m away from the uplink Asus TUF-BE6500.
TR3000 5GHz WiFi --> Acer Swift Go 14 2024 model with built-in Intel BE200 WiFi 7 adapter
System
| Hostname | OpenWrt |
| Model | Cudy TR3000 v1 |
| Architecture | ARMv8 Processor rev 4 |
| Target Platform | mediatek/filogic |
| Firmware Version | OpenWrt 24.10.2 r28739-d9340319c6 / LuCI openwrt-24.10 branch 25.245.48024~b8bc15b |
| Kernel Version | 6.6.93 |
| Local Time | 2025-09-08 12:31:44 |
| Uptime | 0h 52m 9s |
| Load Average | 0.00, 0.02, 0.05 |
Bash:
root@OpenWrt:~/ookla# ./speedtest -s 13623
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 2.54 ms (jitter: 0.33ms, low: 2.35ms, high: 2.97ms)
Download: 1474.27 Mbps (data used: 1.6 GB)
9.10 ms (jitter: 3.49ms, low: 3.61ms, high: 22.29ms)
Upload: 809.48 Mbps (data used: 1.0 GB)
9.41 ms (jitter: 2.83ms, low: 4.04ms, high: 17.87ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/d713d1a5-d1b0-4068-af04-db4a9607cf75
Bash:
PS C:\work\networking\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.88 ms (jitter: 0.65ms, low: 3.18ms, high: 4.38ms)
Download: 1222.64 Mbps (data used: 1.4 GB)
6.23 ms (jitter: 1.90ms, low: 3.46ms, high: 13.93ms)
Upload: 840.99 Mbps (data used: 1.1 GB)
10.86 ms (jitter: 3.99ms, low: 3.81ms, high: 19.61ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/0b4e07e1-23b9-4393-9a25-4377541473e9
Bash:
Speedtest by Ookla
ISP: Singtel Fibre
Idle Latency: 3.64 ms (jitter: 1.19ms, low: 3.29ms, high: 5.64ms)
Download: 663.51 Mbps (data used: 601.2 MB)
23.18 ms (jitter: 9.82ms, low: 6.44ms, high: 58.29ms)
Upload: 549.68 Mbps (data used: 965.7 MB)
18.12 ms (jitter: 12.42ms, low: 7.43ms, high: 540.93ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/72dc65a0-c37f-477c-bbd1-4bd32f67f245
