Openwrt Router Firmware
Cudy TR3000 Travel Router (AX3000, 2.5G port, 1G port, 128MB Flash, 512MB RAM) OpenWRT test.
1. Impression of the stock firmware -- only tested the web UI for like 10 minutes, not too bad, but no SSH access, so no fun.
2. OpenWRT Setup is rather simple. I also tried to use TFTP64 under Windows to restore the Cudy Stock FW as well.
https://openwrt.org/toh/cudy/tr3000
3. I am testing it as the "wireless adapter" for my Windows laptop, similar to the stock FW's WISP mode.
https://openwrt.org/docs/guide-user/network/wifi/connect_client_wifi
Asus TUF-BE6500 (CH60, 160MHz channel bandwidth) -- wireless, 4m away -- Cudy TR3000 (Ch60 5GHz uplink)
Wireless become the WAN device in this case (wwan).
Both Cudy 2.5G and 1G port become LAN ports in this case (I remove the normal WAN port and add it to the br-lan). br-lan now includes both eth0 and eth1.
In this case, TR3000 still has functions like NAT, DHCP and Firewall.
System​
HostnameOpenWrt
ModelCudy TR3000 v1
ArchitectureARMv8 Processor rev 4
Target Platformmediatek/filogic
Firmware VersionOpenWrt 24.10.2 r28739-d9340319c6 / LuCI openwrt-24.10 branch 25.245.48024~b8bc15b
Kernel Version6.6.93
Local Time2025-09-08 12:31:44
Uptime0h 52m 9s
Load Average0.00, 0.02, 0.05
4. SpeedTest results.
4. 1) wwan speedtest from the TR3000 router itself
Bash:
root@OpenWrt:~/ookla# ./speedtest -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.54 ms   (jitter: 0.33ms, low: 2.35ms, high: 2.97ms)
    Download:  1474.27 Mbps (data used: 1.6 GB)
                  9.10 ms   (jitter: 3.49ms, low: 3.61ms, high: 22.29ms)
      Upload:   809.48 Mbps (data used: 1.0 GB)
                  9.41 ms   (jitter: 2.83ms, low: 4.04ms, high: 17.87ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/d713d1a5-d1b0-4068-af04-db4a9607cf75
4.2) Acer Swift Go 14 laptop wired connection speedtest (WiFi disabled)
TR3000 2.5G LAN --> Acer Swift Go 14 2024 model with Ugreen 2.5G network adapter (wired test)
Bash:
PS C:\work\networking\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.88 ms   (jitter: 0.65ms, low: 3.18ms, high: 4.38ms)
    Download:  1222.64 Mbps (data used: 1.4 GB)
                  6.23 ms   (jitter: 1.90ms, low: 3.46ms, high: 13.93ms)
      Upload:   840.99 Mbps (data used: 1.1 GB)
                 10.86 ms   (jitter: 3.99ms, low: 3.81ms, high: 19.61ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/0b4e07e1-23b9-4393-9a25-4377541473e9
4.3) Acer Swift Go 14 laptop wireless connection speedtest (close 50cm range to the TR3000). Take note TR3000 is 4m away from the uplink Asus TUF-BE6500.
TR3000 5GHz WiFi --> Acer Swift Go 14 2024 model with built-in Intel BE200 WiFi 7 adapter
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.64 ms   (jitter: 1.19ms, low: 3.29ms, high: 5.64ms)
    Download:   663.51 Mbps (data used: 601.2 MB)
                 23.18 ms   (jitter: 9.82ms, low: 6.44ms, high: 58.29ms)
      Upload:   549.68 Mbps (data used: 965.7 MB)
                 18.12 ms   (jitter: 12.42ms, low: 7.43ms, high: 540.93ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/72dc65a0-c37f-477c-bbd1-4bd32f67f245
More info about the system.
Bash:
root@OpenWrt:~# cat /etc/os-release
NAME="OpenWrt"
VERSION="24.10.2"
ID="openwrt"
ID_LIKE="lede openwrt"
PRETTY_NAME="OpenWrt 24.10.2"
VERSION_ID="24.10.2"
HOME_URL="https://openwrt.org/"
BUG_URL="https://bugs.openwrt.org/"
SUPPORT_URL="https://forum.openwrt.org/"
BUILD_ID="r28739-d9340319c6"
OPENWRT_BOARD="mediatek/filogic"
OPENWRT_ARCH="aarch64_cortex-a53"
OPENWRT_TAINTS=""
OPENWRT_DEVICE_MANUFACTURER="OpenWrt"
OPENWRT_DEVICE_MANUFACTURER_URL="https://openwrt.org/"
OPENWRT_DEVICE_PRODUCT="Generic"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="OpenWrt 24.10.2 r28739-d9340319c6"
OPENWRT_BUILD_DATE="1750711236"
root@OpenWrt:~# ubus call system board | grep 'model\|description'
        "model": "Cudy TR3000 v1",
                "description": "OpenWrt 24.10.2 r28739-d9340319c6",
root@OpenWrt:~# iwinfo | grep 'Hardware:\|PHY name'
          Hardware: embedded [MediaTek MT7981]
          Supports VAPs: yes  PHY name: phy1
root@OpenWrt:~# iw list | grep 'Wiphy\|TXQS\|AIRTIME_FAIRNESS\|AQL'
Wiphy phy1
                * [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
                * [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
                * [ AQL ]: Airtime Queue Limits (AQL)
Wiphy phy0
root@OpenWrt:~# cat /etc/modules.conf
# examples:
# options mod1 option=val
# blacklist mod2
root@OpenWrt:~# dmesg | grep "WED"
root@OpenWrt:~# free -h
              total        used        free      shared  buff/cache   available
Mem:         497488       89992      353872        1372       53624      356348
Swap:             0           0           0
root@OpenWrt:~# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                 4.8M      4.8M         0 100% /rom
tmpfs                   242.9M      1.3M    241.6M   1% /tmp
/dev/ubi0_2              44.6M      4.3M     37.9M  10% /overlay
overlayfs:/overlay       44.6M      4.3M     37.9M  10% /
tmpfs                   512.0K         0    512.0K   0% /dev
root@OpenWrt:~# cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00100000 00020000 "BL2"
mtd1: 00080000 00020000 "u-boot-env"
mtd2: 00200000 00020000 "Factory"
mtd3: 00040000 00020000 "bdinfo"
mtd4: 00200000 00020000 "FIP"
mtd5: 04000000 00020000 "ubi"
Trying adblock-lean.
https://github.com/lynxthecat/adblock-lean/
Bash:
root@OpenWrtTR3000:~# cat /etc/adblock-lean/config
# adblock-lean configuration options
# config_format=v10
# values must be enclosed in double-quotes
# custom comments are not preserved after automatic config update
# Whitelist mode: only domains (and their subdomains) included in the allowlist(s) are allowed, all other domains are blocked
# In this mode, if blocklists are used in addition to allowlists, subdomains included in the blocklists will be blocked,
# including subdomains of allowed domains
whitelist_mode="0"
# One or more *raw domain* format blocklist/ipv4 blocklist/allowlist URLs and/or short list identifiers separated by spaces
# Short list identifiers have the form of [hagezi|oisd]:[list_name]. Examples: hagezi:tif.mini, oisd:big
blocklist_urls="hagezi:pro hagezi:tif"
blocklist_ipv4_urls=""
allowlist_urls=""
# One or more *dnsmasq format* domain blocklist/ipv4 blocklist/allowlist URLs separated by spaces
dnsmasq_blocklist_urls=""
dnsmasq_blocklist_ipv4_urls=""
dnsmasq_allowlist_urls=""
# Path to optional local *raw domain* allowlist/blocklist files in the form:
# site1.com
# site2.com
local_allowlist_path="/etc/adblock-lean/allowlist"
local_blocklist_path="/etc/adblock-lean/blocklist"
# Test domains are automatically querried after loading the blocklist into dnsmasq,
# in order to verify that the blocklist didn't break DNS resolution
# If query for any of the test domains fails, previous blocklist is restored from backup
# If backup doesn't exist, the blocklist is removed and adblock-lean is stopped
# Leaving this empty will disable verification
test_domains="google.com microsoft.com amazon.com"
# List part failed action:
# This option applies to blocklist/allowlist parts which failed to download or couldn't pass validation checks
# SKIP - skip failed blocklist file part and continue blocklist generation
# STOP - stop blocklist generation (and fall back to previous blocklist if available)
list_part_failed_action="SKIP"
# Maximum number of download retries
max_download_retries="3"
# Minimum number of good lines in final postprocessed blocklist
min_good_line_count="340000"
# Mininum number of lines of any individual downloaded part
min_blocklist_part_line_count="1"
min_blocklist_ipv4_part_line_count="1"
min_allowlist_part_line_count="1"
# Maximum size of any individual downloaded blocklist part
max_file_part_size_KB="24000"
# Maximum total size of combined, processed blocklist
max_blocklist_file_size_KB="29000"
# Whether to perform sorting and deduplication of entries (usually doesn't cause much slowdown, uses a bit more memory) - enable (1) or disable (0)
deduplication="1"
# Utility to compress final blocklist, intermediate blocklist parts and the backup blocklist to save memory
# Supported options: gzip, pigz, zstd or 'none' to disable compression
compression_util="gzip"
# Compression options: passed as-is to the compression utility
# Available options depend on the compression utility. '-[n]' universally specifies compression level.
# Busybox gzip ignores any options.
#   Intermediate compression. Default: '-3'.
intermediate_compression_options="-3"
#   Final blocklist compression. Default: '-6'
final_compression_options="-6"
# unload previous blocklist form memory and restart dnsmasq before generation of
# new blocklist in order to free up memory during generation of new blocklist - 'auto' or enable (1) or disable (0)
unload_blocklist_before_update="auto"
# Start delay in seconds when service is started from system boot
boot_start_delay_s="120"
# Maximal count of download and processing jobs run in parallel. 'auto' sets this value to the count of CPU cores
MAX_PARALLEL_JOBS="auto"
# If a path to custom script is specified and that script defines functions
# 'report_success()', 'report_failure()' or 'report_update()',
# one of these functions will be executed when adblock-lean completes the execution of some commands,
# with corresponding message passed in first argument
# report_success() and report_update() are only executed upon completion of the 'start' command
# Recommended path is '/usr/libexec/abl_custom-script.sh' which the luci app has permission to access
custom_script=""
# Crontab schedule expression for periodic list updates
cron_schedule="0 5 * * *"
# dnsmasq instance indexes and config directories
# normally this should be set automatically by the 'setup' command
DNSMASQ_INDEXES="0"
DNSMASQ_CONF_DIRS="/tmp/dnsmasq.cfg01411c.d"
root@OpenWrtTR3000:~# service adblock-lean status
adblock-lean (version 0.7.4.1) status:
Checking dnsmasq instances.
adblock-lean service is enabled.
Checking the active blocklist.
Using following nameservers for DNS resolution verification: 127.0.0.1, ::1
Testing adblocking.
Testing DNS resolution.
The dnsmasq check passed and the presently installed blocklist has entries count: 845,345.
adblock-lean is active.
Generating dnsmasq stats.
dnsmasq stats available for reading using 'logread'.
Checking for adblock-lean updates.
The locally installed adblock-lean is the latest version.
Waveform.com test results, without any QoS/SQM measures.
Acer laptop -- wired connection to TR3000 (wireless uplink to Asus TUF-BE6500)
Bufferbload Grade A
https://www.waveform.com/tools/bufferbloat?test-id=564effa9-dc91-4ca4-b142-a03e5b5ecf34
As expected, the CPU is too weak to support 1Gbps/1Gbps SQM using Cake (piece-of-cake QoS)..
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     2.84 ms   (jitter: 0.49ms, low: 2.49ms, high: 3.40ms)
    Download:   426.31 Mbps (data used: 213.1 MB)
                  5.84 ms   (jitter: 1.24ms, low: 4.18ms, high: 11.39ms)
      Upload:   809.10 Mbps (data used: 1.0 GB)
                 13.18 ms   (jitter: 2.97ms, low: 6.83ms, high: 20.00ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/df4ba8ef-60d8-40b6-b640-3120a4e1c933
Just nice with 400Mbps/400Mbps SQM using Cake (piece-of-cake QoS).
Bash:
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     3.30 ms   (jitter: 0.95ms, low: 2.80ms, high: 4.33ms)
    Download:   383.73 Mbps (data used: 336.0 MB)
                  4.83 ms   (jitter: 1.26ms, low: 3.20ms, high: 8.29ms)
      Upload:   381.33 Mbps (data used: 178.6 MB)
                  5.52 ms   (jitter: 1.61ms, low: 3.77ms, high: 9.86ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/2338345e-e6d3-4ed3-81ee-28b61f6e06e8
With this SQM settings, Waveform.com Bufferbloat Grade is A.
https://www.waveform.com/tools/bufferbloat?test-id=10128c06-7688-4d8c-96fc-51488513bcae
Tailscale performance (no SQM/QoS)
Acer Swift 14 Go laptop --> wired --> TR3000 --> wireless --> Asus TUF-BE6500 AP --> wired --> OpenWRT 192.168.50.1 (5Gbps uplink, Tailscale subnet router) --> Internet --> OpenWRT 192.168.38.1 (Tailscale subnet router) --> Ubuntu 24.04 Linux LxC container 192.168.38.11.
iperf3 server -- Ubuntu 24.04 Linux LxC container 192.168.38.11.
iperf3 client -- Acer laptop
Bash:
PS C:\work\networking\iperf-3.18-win64> tracert.exe 192.168.38.11
Tracing route to 192.168.38.11 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  OpenWrtTR3000.lan [192.168.1.1]
  2     2 ms     1 ms     1 ms  192.168.50.1
  3     3 ms     2 ms     2 ms  100.116.181.96
  4     4 ms     3 ms     3 ms  192.168.38.11
Trace complete.
PS C:\work\networking\iperf-3.18-win64> .\iperf3.exe -c 192.168.38.11
Connecting to host 192.168.38.11, port 5201
[  5] local 192.168.1.196 port 53251 connected to 192.168.38.11 port 5201
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec   104 MBytes   871 Mbits/sec
[  5]   1.00-2.01   sec   106 MBytes   880 Mbits/sec
[  5]   2.01-3.01   sec   104 MBytes   878 Mbits/sec
[  5]   3.01-4.00   sec   103 MBytes   871 Mbits/sec
[  5]   4.00-5.01   sec  98.4 MBytes   817 Mbits/sec
[  5]   5.01-6.01   sec  98.0 MBytes   829 Mbits/sec
[  5]   6.01-7.00   sec   102 MBytes   855 Mbits/sec
[  5]   7.00-8.01   sec   101 MBytes   840 Mbits/sec
[  5]   8.01-9.01   sec  96.2 MBytes   808 Mbits/sec
[  5]   9.01-10.01  sec  99.9 MBytes   837 Mbits/sec
[  5]   0.00-10.01  sec  1013 MBytes   848 Mbits/sec                  sender
[  5]   0.00-10.02  sec  1010 MBytes   845 Mbits/sec                  receiver
iperf Done.
PS C:\work\networking\iperf-3.18-win64> .\iperf3.exe -c 192.168.38.11 -R
Reverse mode, remote host 192.168.38.11 is sending
[  5] local 192.168.1.196 port 53256 connected to 192.168.38.11 port 5201
[  5]   0.00-1.01   sec  73.8 MBytes   611 Mbits/sec
[  5]   1.01-2.00   sec  78.1 MBytes   661 Mbits/sec
[  5]   2.00-3.01   sec  79.6 MBytes   662 Mbits/sec
[  5]   3.01-4.01   sec  78.2 MBytes   657 Mbits/sec
[  5]   4.01-5.01   sec  79.0 MBytes   666 Mbits/sec
[  5]   5.01-6.01   sec  79.6 MBytes   663 Mbits/sec
[  5]   6.01-7.01   sec  79.0 MBytes   665 Mbits/sec
[  5]   7.01-8.01   sec  79.4 MBytes   669 Mbits/sec
[  5]   8.01-9.00   sec  78.8 MBytes   664 Mbits/sec
[  5]   9.00-10.01  sec  80.0 MBytes   666 Mbits/sec
[ ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-10.01  sec   788 MBytes   661 Mbits/sec    0            sender
[  5]   0.00-10.01  sec   786 MBytes   658 Mbits/sec                  receiver
iperf Done.
Did you try the "Request Build" option in the firmware selector?
Yes, it does not work.
It only provides the useless one.
https://downloads.openwrt.org/relea...s-mt7621-tplink_re350-v1-initramfs-kernel.bin
Custom build error message (with extra "nano" package":
Bash:
Package list missing or not up-to-date, generating it.
Building package index...
Pseudo file "dev" exists in source filesystem "/builder/build_dir/target-mipsel_24kc_musl/root-ramips/dev".
Ignoring, exclude it (-e/-ef) to override.
8170+1 records in
8170+1 records out
4183508 bytes (4.2 MB, 4.0 MiB) copied, 0.0097578 s, 429 MB/s
file-system partition too big (more than 2849159 bytes): Success
stat: cannot statx '/builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-1c50ed03271a-ramips-mt7621-tplink_re350-v1-squashfs-sysupgrade.bin': No such file or directory
bash: line 1: [: 6160384: unary operator expected
    WARNING: Image file /builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-1c50ed03271a-ramips-mt7621-tplink_re350-v1-squashfs-sysupgrade.bin is too big:  > 6160384
Failed to open firmware file
sha256sum: /builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-1c50ed03271a-ramips-mt7621-tplink_re350-v1-squashfs-sysupgrade.bin: No such file or directory
cp: cannot stat '/builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-1c50ed03271a-ramips-mt7621-tplink_re350-v1-squashfs-sysupgrade.bin': No such file or directory
8170+1 records in
8170+1 records out
4183508 bytes (4.2 MB, 4.0 MiB) copied, 0.00934471 s, 448 MB/s
file-system partition too big (more than 2818048 bytes): Success
cp: cannot stat '/builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-1c50ed03271a-ramips-mt7621-tplink_re350-v1-squashfs-factory.bin': No such file or directory
I have another old TP-Link RE305 V1 (AC1200, 100M Ethernet) as well, which does not work with the OpenWRT image. It keeps saying the image checksum error.
OpenWRT data:
https://openwrt.org/toh/hwdata/tp-link/tp-link_re305_v1
Anyway, not going to try too much on this old one (MediaTek MT7628AN single core 580MHz CPU, 8MB RAM, 64MB Flash).
It may work with the origianl V1 FW, but I can not revert back to the original V1 FW.
https://www.tp-link.com/sg/support/download/re305/v1/
I have tried two FW and they do not work.
RE305(AS)_V1_171115Download
Published Date: 2017-11-15Language: Multi-languageFile Size: 5.45MB
RE305(EU)_V1_170227Download
Published Date: 2017-02-27Language: English, Multi-languageFile Size: 5.44 MB
OpenWRT may work with following FW but I cannot downgrade to the following version, same image checksum error.
RE305(UK)_V1_161221Download
Published Date: 2016-12-21Language: English, Multi-languageFile Size: 5.08MB
Custom build error message:
One more try, without "nano" package", just the default build.
Bash:
init
STDERR
7826+1 records in
7826+1 records out
4007144 bytes (4.0 MB, 3.8 MiB) copied, 0.0100159 s, 400 MB/s
stat: cannot statx '/builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-7498d101a456-ramips-mt7621-tplink_re350-v1-squashfs-sysupgrade.bin': No such file or directory
    WARNING: Image file /builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-7498d101a456-ramips-mt7621-tplink_re350-v1-squashfs-sysupgrade.bin is too big:  > 6160384
sha256sum: /builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-7498d101a456-ramips-mt7621-tplink_re350-v1-squashfs-sysupgrade.bin: No such file or directory
cp: cannot stat '/builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-7498d101a456-ramips-mt7621-tplink_re350-v1-squashfs-sysupgrade.bin': No such file or directory
7826+1 records in
7826+1 records out
4007144 bytes (4.0 MB, 3.8 MiB) copied, 0.00961006 s, 417 MB/s
cp: cannot stat '/builder/build_dir/target-mipsel_24kc_musl/linux-ramips_mt7621/tmp/openwrt-24.10.2-7498d101a456-ramips-mt7621-tplink_re350-v1-squashfs-factory.bin': No such file or directory
I am still keeping banip though.
https://openwrt.org/docs/guide-user/services/banip
Not so sure if I want to try Crowdsec or not.
https://openwrt.org/docs/guide-user/services/crowdsec
https://doc.crowdsec.net/u/getting_started/installation/linux/
BTW, I am no longer using Pi-hole or Adguard Home with OpenWRT, even though I still keep the LxC containers on my PVE 9 nodes. I am lazy and just use OpenWRT's built-in adblock-fast.
https://openwrt.org/docs/guide-user/services/ad-blocking
I may want to try the smaller adblock-lean but it does not have offical OpenWRT package.
BBCWatcher
OpenWrt 24.10.3 is now available. Among its many improvements this release adds support for a variant of the Cudy TR3000 wireless router, and it fixes an issue with Xiaomi AX3000T wireless routers with Foresee NAND (still for the Mediatek-based AX3000T).
