rachoon
- Jan 9, 2025
chiu will be the first to replyi dont know man.... will 10gbps enhance my experience in edmw?
What about games cum Windoze? Nonstop patches and those patches r huge.
Do I get any prize to reply first in every thread?chiu will be the first to reply
Did they tell u the parts specs? What source they test speed with? Or what is the thing they r doing now vs after the changei'm thinking of signing up leh... but when i ask ppl ard me they say there is no significant difference in speed?!
when i query them they confirmed already upgraded computer, router and cables to 10gbps port capable but still same same....
how come leh? is it true?
i dont know man i dont want to pay for everything then discover no major improvement....![]()
For me it really have difference.
1 Gbps connection more than sufficient for thatBecome a streamer? Nid to upload n download live video at the same time.
Same here. I just upgraded to 10G due to recontact. Not going to change out the Ubiquiti wireless.Started with M1's original fibre at 100mbps and now they'd upped it to 1Gbps at the same $29.90 price.
i am still on the same set of Ubiquiti Wireless APs that I had installed in my house 8yrs ago.
Nearly maintenance free after so many years. Except the occasional firmware upgrade.
U forgot the final limitation - endpoint.If you only use wifi at home, you get 20gbps also no difference. Your wifi is limited by your router. My wifi 7 max also 1gbps max
Even if I know, won't tell u.Do you have insider news how much profit the ISP is making per month?
So it's like I wear Gucci laikor but my Jeans is Giordano?Ur speed is only as fast as ur endpoints and ur routers.
having 10gbps does jack shiet if ur endpoints are shiet and u are using an el cheapo run of the mill router that looks more like a dumb octopus than a proper router/WAP from a decent company - Aruba, Cisco, Ubiquiti (at the bare minimum).
there are idiots who upgrade home broadband speed but using laptops from 10yrs ago and shietty consumer grade routers that looks like some octopus with 8 antennas that they'd gotten either free from the ISP or some store that sells it for like $300 apiece. Then keep insisting that they'd paid money for speed boost and they get nothing.
know what you'd paid for and ensure your end to end is all optimised properly. Else it's like giving a Lambo to a shiet kiasee driver who drives with the steering wheel glued to their chest.
i only need 500 mbps.
this hasn't changed in like 10 years.
simi endpoint?U forgot the final limitation - endpoint.
If the price is the same, why not.
Now $29.9 can get you 3gbps up to 10gbps depending on the provider.
Sometimes, providers bundle frills like streaming subscriptions so there's added value there.
Your device.simi endpoint?
oh yes. if you use iphone 6 confirm bukeyiYour device.
