The Plastic Model kit hobby thread
samloi
Do you buy online? or in physical shop?
And can you share the thinning ratio?
I used the vallejo one... cannot sia...
vallejo i tried but cannot stick well........maybe cause i dont like to clean with soapy water before hand
Moi still a noob but Mr Hobby seems to strike it well for me
I use about 1:1-1.5 with levelling thinner. better with .5 tip else will clogged
JAson1980
same issue, i dont clean before spraying. lazy. :o
JAson1980
Moi lazier. Unless need to respray dark base in light colour, i don't even bother to use primer.
most of my kits are sprayed without primer.
Especially after i used vallejo. i think i don't know how to use. Its quite horrible. :o
PikaPika33
High Honorary Member
wip
using a sacrificial sd kit to try paint
PikaPika33
What paint you using for this? Now got AMMO ATOM acrylic self leveling paint. Non toxic.
the first batch of paint i anyhow buy back than. should be lacquer.
i switching to acrylic liao
but dont want waste old paints, so use them to practice
Itsthatguy
yes i did, this one $4.0 only :)
primer lor.
i dont want airbrush
say liao
I bought metal figures 120mm and various scales to practise painting, if don't like then I wash it off with thinners and redo with other methods and paint medium.
PikaPika33
i think that take more time :s13:
but can recycle the plastic so not too bad :)
kreja
I got a question. What do you do with completed models? Take a few photos and chuck one side? This question bothering me to start working on my pile of shame.
PikaPika33
put on display, beo when stress :(
