- Feb 9, 2007
ya must share your experience with us once your hoot reaches![]()
Received the headphones on 16 May 2025. Exactly one week after the order was placed on the 9th (via Shopee).
Had a chance to test them yesterday. These are first impressions, from about 30 minutes of trying them out.
I have the Sony WH-1000XM5 for comparison.
These UGREEN cans are not better than the Sony headphones. They are decent value-for-money though.
The ANC is slightly weaker than the Sony's. Without any input but with the ANC on, both pairs of headphones block out a good amount of environment noise (XM5 was a tad better). Main difference is, with ANC on, the UGREEN Studio Pro do not enhance the sound quality of the audio, unlike the (much) more expensive pair.
The ear padding are more comfortable, but do not give as close a seal as the Sony pair. The UGREEN headphones are heftier...but not in a good way, since portability and comfort for extended-sitting-on-the-head dictate that the headphones should be lighter.
There are more moving parts on the UGREEN pair. The extension of the headphones are on the band, while the earcups can be rotated 90° for carrying or resting on the neck. The Sony XM5's moving parts are on the earcups themselves, both for extension & inward rotation.
The UGREEN app is an APK file which downloaded & installed fine on my Android device. Updated the firmware immediately.
For whatever reason, when paired with my PC via Bluetooth, there is a sync issue with the audio vis-a-vis the video. The audio is just slightly quicker than the video. After adjusting (disabling) the enhancements, there was slight improvement, but the non-sync(?) is still visible, which is irritating. Would not be an issue with music files, I'm guessing?
No such issues with my Sony headphones & various other wireless earphones.
Finally, these <$50 pair of headphones do not come with a carry case.
