jericho75
- May 24, 2013
good meh? also made in some oem factories. paste logo one.
thx , will consider these. currently still using my samsung galaxy buds live
I tot anker is good?QCY is good
Does ANC on these earbuds even works?
good value for moneyI tot anker is good?
Why the brand logo look like NHK logo sia
Btw..... I heard qcy is the oem of many branded earbud.
Ooh, can't wait for the 76th Kohaku Uta Gassen on New Year's Eve :0listen to japanese songs is good.
can use lah ... u never try before lol$6 cannot use one lah.
Can improve sound quality while keeping to a budget also.... the trick is to get chifi IEM that you like... can be had anywhere from $6 to few hundreds.. depends on your taste... but let's say you like heavy bass while vocal is clear... can get a budget dual dynamic drivers IEM like Castor Pro... which is around $20... then get a wireless earhooks with charging case that turn the wired IEM into a wireless earbuds with ANC.. which is around $30+ end up cheaper than what TS paid for. Best part is that it is all modular... let's say suay suay 1 year later the battery failed... you only need to buy the $30+ earhooks with charging case again... while the IEM can be used again. Or you suay suay IEM died... you just replace the $20 IEM lor...Aiya I tell you all la..no need spend simi 100-200 buy simi satki jbl or jabra earbuds.
Just hoot qcy, anker, aukey or basus these kind can already.
好听就是好听. 不好听就是不好听.
Simple as that.
technology improved and costs have gone down ... 2018 is like 7 years back lol2018 i got some cheapo earbud leecommend by bbfa here. kept cut off and unusable one
Anytime you feel like you want a different sound... just upgrade the IEM lor.
add Tanchjim Bunny to the list, the usb-c dsp version... The app got 4 presets, or use the parametric eq. Damn versatile, buy the wireless hook for bluetooth, or just use wired with your usb-c phoneHehe...BW effort gao gao but many wont go down the rabit hole de...
Unless one gets to hear the really cheap and good IEMs
- Chu 2
- Waner/ Studio edition
- KZ EDC pro
- Salnotes Zero/2
and find them 10x more superior than the budget TWS....then maybe got incentive to adopt
