The EasyAbroad app.The droidong app?
i guess if you have a main phone then ok ahcoming back to huawei see see
now nobody using lighthouse for GMS ?
so far no issue for my daily activities on p50pro kirin set previously in sg
for apps 1st priority is HMS then follow by aurora store
i dun even need app like micro g actually
using kirin harmony OS as main phone previouslyi guess if you have a main phone then ok ah
good news! Seems like the global launch of Harmony OS Next is nearNo need. Both can be installed from EasyAbroad and work as is.
I think Huawei phones are secure. Local banking apps and SingPass work. No issues for me on Harmony 6.0.My opinion is that one might need another Iphone/android to run certain important and secure apps if using Huawei phones in the long run
Do they get regular security updates? Those on emui don't get regular security updates I believeI think Huawei phones are secure. Local banking apps and SingPass work. No issues for me on Harmony 6.0.
My phone security patch is updated to Oct 1, 2025. So should be safe.Do they get regular security updates? Those on emui don't get regular security updates I believe
I see thanks for sharing. Bought a huawei mate pad se earlier this year, it's stuck at harmony os 2. My p30 pro is also stuck at emui 12.I use a Huawei Mate X6 with EMUI 15. I do get updates, last being in September 2025.
I am on EMUI and use it as my main phone. There are monthly security Android updates. I will jump HarmonyOS NEXT once it's available. Those apps that are not on HarmonyOS, I will not use them anymore.Do they get regular security updates? Those on emui don't get regular security updates I believe
Security updates is different from OS update.I see thanks for sharing. Bought a huawei mate pad se earlier this year, it's stuck at harmony os 2. My p30 pro is also stuck at emui 12.
I am still waiting for global release.I am on EMUI and use it as my main phone. There are monthly security Android updates. I will jump HarmonyOS NEXT once it's available. Those apps that are not on HarmonyOS, I will not use them anymore.
Which huawei phone u using now? Seems like huawei abandoned their customers on older phones... The last security update I got was like 2-3 years ago...I am on EMUI and use it as my main phone. There are monthly security Android updates. I will jump HarmonyOS NEXT once it's available. Those apps that are not on HarmonyOS, I will not use them anymore.
Yes as long as you have the supported credit card, UnionPay from ICBC is supported. There are supported cards from BOC too.Anyone managed to setup payment via Huawei pay?
P60 Pro. I just got security update this month.Which huawei phone u using now? Seems like huawei abandoned their customers on older phones... The last security update I got was like 2-3 years ago...
