Huawei Pura X
vaxvms
coming back to huawei see see
now nobody using lighthouse for GMS ?
so far no issue for my daily activities on p50pro kirin set previously in sg
for apps 1st priority is HMS then follow by aurora store
i dun even need app like micro g actually
perfectlight
i guess if you have a main phone then ok ah
jeffrey745
My opinion is that one might need another Iphone/android to run certain important and secure apps if using Huawei phones in the long run
Pynchmail
I think Huawei phones are secure. Local banking apps and SingPass work. No issues for me on Harmony 6.0.
jeffrey745
I use a Huawei Mate X6 with EMUI 15. I do get updates, last being in September 2025.
I see thanks for sharing. Bought a huawei mate pad se earlier this year, it's stuck at harmony os 2. My p30 pro is also stuck at emui 12.
OutBreak
I am on EMUI and use it as my main phone. There are monthly security Android updates. I will jump HarmonyOS NEXT once it's available. Those apps that are not on HarmonyOS, I will not use them anymore.
I am still waiting for global release.
jeffrey745
Which huawei phone u using now? Seems like huawei abandoned their customers on older phones... The last security update I got was like 2-3 years ago...
1982-1994
i intend to stick to harmonyOS 4.2 on xt ultimate as long as i owned it *fingers crossed*, instead of updating it to NEXT
Most banking and singpass apps are on another spare phone
RaebRalop
Just received the 2025 matepad mini , trying to figure out where to find the usual app....in DroiTong also nothing much leh....does the default appgallery need to change region or something ?
