previously malaysia only got DNB which provide 5g coverage to all the telco. UM now is building the second 5G network in Malaysia under 5G SA protocol. that mean less congested and double 5g network to cover for DNB blindspot.
It is kind of hidden now8 no more $8 for 4g??
Now $11.80 ?
Slow down 4g speed and increase the price. Good move. Eight.
Now $11.80 ?
Yup, but you cannot find any details on those plans on the links, only option to sign up.Not really hidden but under the other plans.
https://www.eight.com.sg/
At the top, you have Eight Home Internet, S$18 5G plan, S$14.8 5G plan and S$11.8 4G plan.
At the bottom there are four more options.
Looking for our $8 Double Eight plan?
BUY NOW
Senior Plan available
BUY NOW
Data only SIM available
buy now
Prefer to buy in stores?
FIND US
This is the exact reason that I went with Eight. The free roaming voice call is ICE as I still have old folks at home.One main advantage for Eight and SIMBA over CMLink and CUniq is free voice roaming which can be useful.
BTW, CUniq S$14.9 4G plan seems to offer more China data than CMLink S$21 5G plan.
https://www.cuniq.sg/en/plans/listing
- 35GB Roaming Data in Mainland China
- ✓20GB APAC*Roaming Data
The 4G network 18GB allowance is good enough for a three weeks trip. I feel the 5G network is consuming much more data when using it.
3 big telco for you to choose also got blind spot a? then must be a ulu place liao.dun be too optimistic on this.
bolehland is having much much larger geographical area than lion city.
even lion city until today u cannot get super fast speed and good coverage indoor. not to mention about bolehland.
while it looks good on paper for what they offer, in real life, if u cannot enjoy it, it is also an empty promise.
even 4G has been aroud for so long in bolehland, again there are blind spots.
Ah, from $8 plan, I upgraded to the $18 plan. The 2GB allowance finished in 3 days, mainly using navigation. After I upgraded to the $18 plan, the 5G appeared, and it burned 1GB in a day with similar usage. While at $8 plan, I’m unable to connect to 5G network.Yes, roaming voice is good to have.
I only see 12 GB roaming data for S$8 4G plan. Do you have 18GB as part of promotion?
10GB APAC Roaming2GB Intl Roaming
The S$11.9 4G plan has more roaming bundle.
26GB APAC Roaming8GB Intl Roaming
For roaming, it may not depend on your Eight plan is 4G plan or 5G plan, but rather depends on the roaming partner of Eight.
On the other hand, you can always set your phone to use 4G instead of 5G if 4G speed is good enough. And in many countries 5G coverage may not be good as 4G so it may be a good idea to use 4G anyway.
if u hardly in bolehland and just once in a while roam there u could never know.3 big telco for you to choose also got blind spot a? then must be a ulu place liao.![]()
good choice. i find eight the best plan to use. especially if u roam a lot.Just ported zym 7.7 to eight $8 plan, hope it is good...
yes, they purposely 'hide' it actually.It is kind of hidden now
https://account.eight.com.sg/activa...Md193Y0I.*_gcl_au*OTM1MTU5ODQ0LjE3NTkxMzk1Njk.
You may like to download the map in advance before proceeding to the locations, it will use much less data.Ah, from $8 plan, I upgraded to the $18 plan. The 2GB allowance finished in 3 days, mainly using navigation. After I upgraded to the $18 plan, the 5G appeared, and it burned 1GB in a day with similar usage. While at $8 plan, I’m unable to connect to 5G network.
BTW, in shopee, what's the difference between Renewal $8 and Main Wallet $8?good choice. i find eight the best plan to use. especially if u roam a lot.
the zero worry about extra cost is super useful.
Main Wallet your $8 will go into your account wallet for later deduction.BTW, in shopee, what's the difference between Renewal $8 and Main Wallet $8?
Thanks!
