- Sep 16, 2018
Not sure if i missed anything but i tried reverse the password used for the "Admin" login for the "support" login but failed.
Also tried the password as is but also failed for the "support" id.
Device name XS-240X-A
Vendor Nokia
Software Version: 3TN00284JJLI18(1.2401.318)
Appreciate if anyone can advise.
Have you changed the Admin password? Is the Admin password the same as printed on the label?
If not the same, revert back to the password printed on the label. Then try again.
If the Admin password is the same as the one printed on the label, then your case may be a bit more complicated.
I remember one user had the same problem. I think in the end he sorted out the issue by factory reset. But that may render your services temporarily not available, especially Singtel TV and Singtel Digital Voice. The services did come back later.
Proceed at your own risk. Worst case you may have to call SingTel to recover and you may need to pay for the recovery service.
