Need some advise:
Current M1 BB contract ends Jul2026, 1Gbps @ $36.84. Using my own router Asus TUF Gaming AX4200
Now i received an offer for "free speed upgrade" to 6Gbps @ the same price of $36.84 with free Asus RT BE92U. Basically super early recontract?
Wise to take up this offer? And if so should i continue using current router and sell new one, Or use new BE92U and sell the old wifi 6 router?
I will say it is okay to recontract.
If you do not have issues with the current TUF-AX4200, you can sell the new RT-BE92U to offset the monthly subscription price by quite a bit (say, selling at S$264 and reduce S$11 per month). TUF-AX4200 is also supported by OpenWRT. So it can enjoy long security updates even after Asus stops the support in the future.
If you like to see great SpeedTest number, you can go with RT-BE92U.
Jurong640
Need some advise:
When they say free speed upgrade, did they say it would be continuing with the contract or re-contract?
Take note that the new re-contract price will be discounted off, after 24-months, price will revert to $90++. You have to put into your calendar to re-contract timely, otherwise you might be shocked when you receive your bill on the 25th month.
IndigoHue
"The promotional subscription rate, based on the current monthly rate of each service line, will apply to the recontracted M1 Fibre Broadband plan for 24 months from the ONT installation date; thereafter, applicable non-discounted rate for the M1 Fibre Broadband plan will apply."
Yes it seems what you said is true, that it will revert to non-discounted rate i.e. $90 after 24mths. Thanks for pointing that out.
Does that also mean my current 24mth contract ending Jul 2026, if not recontracted on time, will revert to non-discounted rate? This plan was signed as a new M1 BB user.
IndigoHue
Max cap for TUF AX4200 is 2.5gbps? In that case it will bottleneck the 6gbps yeah. But not sure if in real life use i will notice a difference.
Does the BE92U have significant improvement in wifi range over TUF AX4200? Or other tangible benefits?
TrueB1ue
Anyone know, is there a way to use Voip software for home phone instead of buying a physical phone? Meaning using laptop or mobile phone to call n pickup call using BB home phone number?
No real life difference for 99% of users
Unless you are like me since I want to see WiFi 7 speed at above 2 Gbps or even 3Gbps occasionally. :ROFLMAO:
I don't think RT-BE92U to have much greater WiFi range than TUF-AX4200. In fact 2.4GHz range may be worse.
I am visiting China and the relative only has 100 Mbps Fibre Internet and low end Huawei AX2 router (AX1500). It is actually pretty smooth when I use WiFi and Wireguard VPN on my Singapore home router.
IndigoHue
Does it help with loading/buffering youtube 4k vids faster? Cos i do experience slow buffering at times with the current setup, especially with many tabs open
Also if given TP link BE805 vs Asus RT-BE92U as new router, which is better?
twosix
U sure it is not cos' ur pc is not powerful.enough?
My friend was offered $34.90 for 10gbps renewal. no router though.
That is the normal recontract offer for M1 10Gbps plan.
You may want to sign up as new user to enjoy the S$30.90 Christmas Offer, if your contract has expired or close to expire date.
dgeralds
Does this comes with router? The website didn't say anything about router.
Also can a current user without contract can sign up as a new user?
1) No router bundle. If you need a router bundle, I will actually recommend M1 6Gbps recontract offer at about S$36.90 per month with free Asus Archer BE805 or Asus RT-BE92U. Please check with M1 on your specific recontract offer.
2) Yes in general. You may want to go to M1 Shop to check.
ykeen
Moderator
Moderator
Don't think M1 provides the SIP credentials for retail customers, easiest is just buy a cheap DECT phone to use.
Or you can get something like Grandstream HT813 to connect the FXO to the phoneline and pair with Asterisk, if you REALLY want it to appear as a SIP softphone on your laptop or phone.. although I don't think that is what you want..
TrueB1ue
I just thinking, since the home phone is plug into the box. If can receive the call directly from mobile phone or laptop then no need rush to pickup call from a single cordless phone in the living room and save the money to buy the phone every few years.
tuntun
tech just came to setup. give HN8250Ts-20 ONT. anyway can configure port 1-4 as ONR? only 10Gbps port only able to connect now...
007Mi6
Currently using 1gbps with Asus AX6000 with contract until 2026 June. Paying $36.84 per month
was sent an email to recontract to 6gbps at same rate with a basic free router. Not sure if I should get it. Any wise advice?
toastboxlover
If you find 1gbps to be plenty, can consider StarHub 3gbps passion card promotion at 29.55 and sell the free router
