Hmm rather stingy of HDB not to provide even 1 Lan point to the bedroomdont have, i diy pull from DB to living room,
ont, router, pfsense, dac all in 1 shelf![]()
me use the amoured version, not sure any tougher. but i install 2
i take bus only
hardly take mrt
HDB by default have lan port to all room. But devices have to be at DB.Hmm rather stingy of HDB not to provide even 1 Lan point to the bedroom
Okay then. Coz I am considering buying a ubiquiti unifi gateway at DB box then Lan to a AP at the room areaHDB by default have lan port to all room. But devices have to be at DB.
Me only need lan at 1 area so installing at living room is easier
This should be idea cause the db is like lan room which use the HDB lan port to other roomOkay then. Coz I am considering buying a ubiquiti unifi gateway at DB box then Lan to a AP at the room area
New BTOs now provide 6 LAN points, one in the shelter, one in the function room, one in the kitchen, one in the living room, two in the bedroom.Hmm rather stingy of HDB not to provide even 1 Lan point to the bedroom
U can keep the ONT in the DB, and use the lan point to the living room to connect to the router to improve wifi coverage.HDB by default have lan port to all room. But devices have to be at DB.
I did think of that. And That mean when I switch off I have to go 2 locationU can keep the ONT in the DB, and use the lan point to the living room to connect to the router to improve wifi coverage.
I see.... I thought u would just leave them running 24/7.I did think of that. And That mean when I switch off I have to go 2 location
That the reason I house everything in 1 area
Every cent save is going to aircon and i prefer to off if not using as me stay lone if there electric fire mean no one to spot itI see.... I thought u would just leave them running 24/7.
So are u gonna turn off all appliances? Like fridge etc?Every cent save is going to aircon and i prefer to off if not using as me stay lone if there electric fire mean no one to spot it
Only fridge and ac is on, the rest offSo are u gonna turn off all appliances? Like fridge etc?![]()
But to be frank, if I were to go on holiday say 3 days or more, I will probably do the same as u and turn off all home appliances including fridge and ac for the period.Only fridge and ac is on, the rest off
My small 2 rm have 3 fire rated door. No scare
i cant cause if i do that my ac will need to on and off weekly. fridge need to be empty if i do thisBut to be frank, if I were to go on holiday say 3 days or more, I will probably do the same as u and turn off all home appliances including fridge and ac for the period.
got from TB la, to store batteryKing kor from SAF engineer formation ah?
