DriftKing
There is no stated limit. For Office, there is a hidden limit so I assume Windows should have one too.
I hit the limit for my Office 2007 (made full use of it, can install on 3 PCs at a time :D) and then have to kpkb to MS customer service. They gave me a new key. :)
For Windows, I have yet to hit the limit but I have 3 retail keys to play around with.
Interesting, I couldn't manage to activate windows. Suspecting that my old setup is still on win10 and new one win11. I will update old one to win11 and see if it will be compatible.
Quick run of BF6, wah I think I've been playing handicap for the longest time. Never felt so smooth before.
Lian LI 217 INF, didn't change any fan setting is pretty loud. It's a much bigger( fatter) case than expected. And Holy crap 5080 is twice longer than my old 1080ti !
TiedInsurer
Hi guys. Hardware noob here. Want to buy a gaming PC but my understanding is that brands like Republic of Gamers are generally a rip off? Any recommendations on what to buy? My knowledge on hardware is basically limited to knowing where to plug what. I've bought individual parts at SLS before and put it together, but when i bought the parts, i had no idea what i was doing and going completely based on salesman recommendations.
I saw in an earlier post somebody said it's cheaper to buy from Aftershock or Invader, instead of buying individual parts? So that's where i'm leaning towards right now. Anything i should watch out for before i commit?
The PC is for playing the latest games like When Winds Meet and Stellar Blade, on as high graphics settings as possible with no dropped frames. I prefer single player games so things like latency isn't a priority. Budget is at $1.5k but i can go up to $2k if needed. Hope this budget enough to play on ultra settings smoothly.
TiedInsurer
I'm trying to decide between these three:
Choice 1: https://aftershockpc.com/products/level-5-x3d-amd-ryzen-7-7800x3d-geforce-rtx-5070
Choice 2: https://aftershockpc.com/products/amd-combo-level-5-ryzen-5-8400f-radeon-rx-9070 (will add the 32GB RAM add-on for extra $70.
Choice 3: https://aftershockpc.com/products/nzxt-h3-special-1-black-l3x-amd-ryzen-5-7500f-rtx-5060ti
Choice 1 is mainly due to the fact that it has a Geforce GPU, with AMD's X3D processor. But it's a lot more expensive then the others at $1899. However, i note that their benchmark says that AAA games can only run at medium settings at 4k resolution, for some reason?
Choice 2 is cheap, but it has Powercolor Radeon RX 9070 Reaper for a GPU, which i'm told isn't ideal? The RAM issue is solved by adding $70 to upgrade. And for some reason this setup can supposely run at high settings on 4k resolution. Better then choice 1, even though it seems weaker on every metric? How come?
Choice 3 was recommended by Aftershock sales team, but i have a feeling they just trying to dump an expensive chassis on me. I don't give a **** about form. Just want functionality.
TiedInsurer
From what google says, choice 1 cannot support 4k games because the GPU is only 12GB.... so i will need a 16GB GPU. Which brings me to choice 4: https://www.invaderpc.com/product/specs61/
But this one burst budget liao hahaha.
Anyway right now leaning towards choice 4.... will end up costing $2.5k if i add in the OS, a speaker, and a basic keyboard + mouse. Anything i should watch out for?
tk
Can consider this for $2k budget.. unless u really want Nvidia, but as u know 5070 is 12gb, while 5070ti may burst your budget..
https://www.invaderpc.com/product/specm44/
TiedInsurer
I was told that Nvudia GPUs and AMD's X3D are best in class for gaming purposes, so i'm trying to get both in my build haha. If i have to burst budget by $100+, so be it....
Btw, my choice 4, with regards to future proofing and bottlenecking, what are the things i need to watch out for? If in the near future it starts to fall behind, can i just upgrade to 2x24GB RAM? Or would the bottleneck be elsewhere?
iceblendedchoc
No need to burst
I have a setup with a 9070xt with 7600 and another setup with a 7800x3d with a 5070ti on 4K and 1440p monitors.
No issue running 4k with either setup .
At 4K , for most games , the cpu not going to make a lot of difference maybe just 1 frame more !
bare minimum go for a 9070xt with a 7600 processor or even 7500f
NightRaven49
very much the case now, as ssd and especially ram pricing has gone berserk for diy (can compare with pricing from less than 3 months ago on first page). not to say prebuilt is not affected, but their increase is not as crazy for now, so better to faster buy. what i would look out for is the quality of component selection outside of the cpu and gpu, usually aftershock skimps too much on parts like the mobo and psu imo. invader base spec also not amazing, but at least they offer u upgrade options for all parts.
1.5k is enough for a good experience, based on my brief research seems like a 5060ti 16gb is sufficient for 1440p60 ultra settings for both mentioned games, even 4k60 might be doable with dlss. the alternative 9060xt is generally evenly matched across many games but seems a lot slower in those 2 titles, though i could not find much comparable benchmark data.
suggest looking for an am5 + 5060ti 16gb build, i see invader starting price is just under 1.4k, which seems a bit high based on what i remember but isnt super outrageous.
the 9070 actually beats the 5070 in raw raster (ie non raytraced games), plus packs extra vram which is crucial for higher resolutions. personally i would avoid this choice as it sacrifices too much to be under that 1.5k price point, for eg the 8400f is very anaemic for gaming and i would not be surprised if it ends up holding back the gpu.
not necessarily, u can always tune the graphical settings to have the game fit in the 12gb vram buffer.
u dont have to buy a windows key ;)
i would opt for the ryzen 7 7700 version for a $100+ saving as the 9700x is barely faster for gaming. the 5070ti version is ~15% more expensive but offers ~30% more performance in stellar blade so is technically better perf per dollar, though the 9070xt still offers a solid experience.
x3d may not be worth it depending on the resolution and refresh rate u are targeting, as iceblendedchoc mentioned. speaking of which, what are they for u?
TiedInsurer
Thanks for the suggestion!
Lmao okay. Just went to check and realised ppl are selling these for like $15 on carousell.
I intend to pair this CPU with a Alienware AW3225QF monitor. So 4K at 240hz refresh rate. I doubt i can tell the difference at higher refresh rares anyway haha.
NightRaven49
oh then ur budget definitely not enough to max out ur monitor, maybe a 5090 can come close with dlss haha. but if ok with ~100 fps @ 4k, a 5060ti with dlss should be enough. speaking of which,
u probably dont need a x3d processor for 4k [1] [2]. for this budget/performance tier, paying extra for x3d will likely net u no increase in performance.
PES1989
Managed to boot up my 1st self assembly gaming rig, after watching multiple YouTube videos & struggling in the process, hardest part for me is connecting the right cables to the correct pins, not so much on cable management.
Ask u guys, do u all use ethernet cable or buy wifi adapter to connect to your house wifi router?
I haven’t purchase the Windows key yet as Shopee have it at $12.99 before coins deduction.
TiedInsurer
Oh that's disappointing.... i thought Choice 4 would be able to support 240 fps @ 4k... guess i was too optimistic.
Hmm if the x3d processor will only be useful for 1080p, then i probably won't need it since i want to game at 4k. Will downgrade to 7700. Thanks.
deepblue_82
if u have a lan port nearby of coz use cable...
yes if u see it cheap on shopee just get it..
deepblue_82
240fps @ 4k on 5070ti? on cs go and dota 2 yes
but on normal on AA or AAA titles u have to aim higher like 5090 which now cost a arm and a leg...
x3d is best for gaming.. but it will eat in the to budget
TiedInsurer
5090 will push prices to $3k+ haha...
deepblue_82
thought 9070xt is in the 5070ti league. so have to compare with 5070ti instead of 5090.
sorry wrong words used... 9070xt in term of price to performance is like that best thing at the moment...
not comparing with 5090 which cost anywhere from 3-6 k....
iceblendedchoc
best value for money now is 9070xt. Hurry and buy, ram price, ssd price going up. even gpu going up in jan 2026.
On a sidenote, bought a 5060ti 16gb for $540 last night from shoppee after $120 discount to play with
deepblue_82
so the mem bus 128 really no bottleneck? this is only res why i am not getting the ti....
bro please share link....
