- Nov 27, 2000
Maxx seems to be improving. My home has sporadic 5G signals, usually slow 4G. But these few days seem to be 5G most of the time, and Speedtest ~700Mbps. Haha
I think of moving to cmlink. Kind of screwed this Maxxi port my maxx plan out to vivifi like 1 month ago, and been using vivifi, defnitely much better than m1 maxx which keep giving me frustration ,
what other plan to try? i got another 3 m1 maxx line, my wife my mum my dad, i want to port them all our to other, i am looking at zym or zero1 also
Don’t wait when you spot a good deal. Similar to $3.3 CL deal. 9 months free ST MVNOs deal etc..Was on 7.90 plan and wanted to port to $10 5G... but 2 days too late. I went to change sim today but realised no more 10 dollar plan to changed to... now is to 12 dollar one with 5G. A bit sway.
Maxx base plan is still there. But you must use one month of $10 plan first, let it lapse and it will fall to base plan on the second month.Can i still get M1 Maxx base plan? want to port in my spare simba line and just use for free... more for maintaining the line
Yes, suggest to buy $10 plan with retail shop, save you the hassle to cancel auto CC deduction if get it online.Can i still get M1 Maxx base plan? want to port in my spare simba line and just use for free... more for maintaining the line
But base plan cannot do anything right? Only for parking the number there right?Maxx base plan is still there. But you must use one month of $10 plan first, let it lapse and it will fall to base plan on the second month.
However, be sure to sign up from a retailer and not online. If you sign up online, your plan will be recurring charge and will not fall back to base plan.
People like to keep free things. Haha.But base plan cannot do anything right? Only for parking the number there right?
10min outgoing call, 50SMS and 200mb data monthly. Not forget to mention free incoming calls and SMS. That is actually quite useful compared to parking with Prepaid or using data only plan.But base plan cannot do anything right? Only for parking the number there right?
Reason why I'm asking is because I got 1 number that I like which is currently on this base plan, which I'm thinking to port out. Is there a limit to the validity of this base plan before it will be deleted? Cause it's not inserted to any phones right now.10min outgoing call, 50SMS and 200mb data monthly. Not forget to mention free incoming calls and SMS. That is actually quite useful compared to parking with Prepaid or using data only plan.
If you did not make any call or send an SMS or use some data for >90days, it may be terminated. You may like to insert and install Maxx app to check its status? Ignore the window saying "You have no active subscription, purchase a new plan to start using Maxx again". That is merely a default window for Base Plan status. Just check Base Plan window which indicates next reset date.Reason why I'm asking is because I got 1 number that I like which is currently on this base plan, which I'm thinking to port out. Is there a limit to the validity of this base plan before it will be deleted? Cause it's not inserted to any phones right now.
Hi, it says resets on 28 Dec 2025, means what? It will delete on that day? Number still be gone?If you did not make any call or send an SMS or use some data for >90days, it may be terminated. You may like to insert and install Maxx app to check its status? Ignore the window saying "You have no active subscription, purchase a new plan to start using Maxx again". That is merely a default window for Base Plan status. Just check Base Plan window which indicates next reset date.
No, it means it will be valid on 28 Dec 2025 and probably reset for another month, so on and so forth. Your line is active, you are free to port out anytime.Hi, it says resets on 28 Dec 2025, means what? It will delete on that day? Number still be gone?
No, it has been free for many months though the terms and conditions indicates otherwise.Will they charge a $5 subscription fee for base plan from 3rd month onwards?
Not as of now, until they change their T&Cs. But you must keep your line active monthly, by sending sms, make a call or use some dataWill they charge a $5 subscription fee for base plan from 3rd month onwards?
that is one reason. another reason is to use it as a burner number to register for new accounts with various business.Reason why I'm asking is because I got 1 number that I like which is currently on this base plan, which I'm thinking to port out. Is there a limit to the validity of this base plan before it will be deleted? Cause it's not inserted to any phones right now.
Maxx Indeed reinstates the original condition as follows:Not as of now, until they change their T&Cs. But you must keep your line active monthly, by sending sms, make a call or use some data
