kage
Wasted should have bought last week from invader, the price of Ryzen 7 7000 wif 9070xt now can get 5070ti wif Ryzen 7 7000 then .... Slightly cheaper too
Now all system price up ....
Have to look to buy else where aredy , any recommendations expert here?? :(
jinsatkilife
the longer u wait, the more it will rise
if not, just wait 1-2 years and see how
yukita
actually its no brainer already, should bought earlier. all indicator shows price will go up. the longer you wait, the pricier it going to be.
Koenig168
If you intend to upgrade within the next 3 years, just hoot 32GB of DDR5 now and get the rest later. DDR5 prices will not come down anytime soon.
yukita
I hoot alot from Amazon, when receive the ram, i can re-sell it become freelance scalper.
yukita
they adding weights plate le is how they get past amazon de complete checks
wait tonight i open.
btw, i read amd platform difficult to run ram higher than 6000. since this kit is 6400 cl 32, can i just load XMP then lower the speed to 6000 cl32? or maybe 6000 cl30?
MangoCAT
Not sure for the xmp/bios. (Not complete knowledge to help)
Up for helps.
Koenig168
You will know when you test. 96GB is more demanding on the IMC so even the rated 6400 cl32 is not guaranteed.
yukita
I just plug in the ram without resetting the bios, after memory training (i think) it boot up follow the setting of my Crucial Pro 6000 CL 36 2x16GB (using Expo). After Restart, go to BIOS, i just enable XMP, and it boot up at 6400 CL 32.
Using HWInfo i checked on Infinity Fabric Clock (FCLK) shows 1996.4 Mhz while Memory Controller Clock (UCLK) shows 3194.2 Mhz.
Is this means the ram works fine? anything i should take note of?
What is the program you use to test the ram stability? can advise?
Edit: The Ram is SK Hynix M-Die, if anyone interested to know.
Edit2: set the FCLK to 2133 and run y-cruncher VT3 test only for over 30 minutes passed. How long to test ?
Koenig168
I use Memtest86 followed by TimeSpy stress test. The latter is a GPU test but I use it to make sure that the system is stable. I don't need y-cruncher etc for my use case.
Seems like you got a good kit from the tests so far.
gatx105
entry level 1440p gaming pc, total: $998
ryzen 5 5600 + asrock b550m wifi se266techdeals
gskill ripjaws v 2x 8gb 3600c18 ddr452tradepac
crucial p3 plus 1tb80dynacore
intel arc b580375dynacore
thermalright tg650s75dynacore
Hi all,
May I know if this build from the main page hardware still ok for a build now, my current pc already having some issue on and off. Will like to build one pc to at least last hopefully passed this AI boom boom price rocket.
yukita
Yeah, so far looks good with the 1:1 and fclk of 2133. Everything runs as expected, finger crossed.
Just now did a single TimeSpy benchmark, it runs fine. I think i just use it first. only when have stability issue then check again. My target actually to get the ram run at 6000 cl 36 already good enough. anything above is bonus.
beng035
Hi all,
its a very decent build. Change 5600 to 5600G. Can last for at least 3 to 5 years. More if hardware does not fail you. If you like a bit of bling, go to shopee or carousell , get the AMD wraith prism cooler.
With B550 mobo, you can upgrade to better chip next time when needed.
