Currently using 1gbps with Asus AX6000 with contract until 2026 June. Paying $36.84 per month
was sent an email to recontract to 6gbps at same rate with a basic free router. Not sure if I should get it. Any wise advice?
The router bundle should be TP-Link Archer BE805 or Asus RT-BE92U, I think the offer is worth going. Both are pretty powerful and not really a "basic free router".
You can choose to keep using your Asus router (is it Asus GT-AX6000 or TUF-AX6000 or RT-AX88U?) and sell the bundled router at about S$264 for quick sell (or higher price). Effective price becomes S$25.84 for M1 6Gbps.
You can also choose to go with Asus RT-BE92U to form AImesh with your existing Asus router.
007Mi6
Hi, thanks for your advice.
I am currently using the ROG GT-AX6000 with a basic router Asus RT-AX3000 to form a Mesh.
not too sure if it makes sense to take up the upgrade offer, get the Asus BT10 and sell off both GT-AX6000 ($100) and RT-AX3000 ($50).
currently, the IOT devices like my washer, aircon, ceiling fans and some grow lights for my plants are connected to the same 2.4Ghz network. Thinking of separating them to an independent network. Would the BT10 make it work?
ROG GT-AX6000 supports VLAN and Guest Network Pro function. You can utilize the feature for your seperation of 2.4GHz IoT devices.
https://www.asus.com/sg/support/faq/1049415/
https://www.asus.com/sg/support/faq/1049414/
Asus ZenWiFi BT10 also supports Asus Smart Home Master function. It is not as good as GT-AX6000 though.
https://www.asus.com/sg/support/faq/1053554/
I'm unable to access 1 specific china site since few days ago on m1 fibre. No issue with other isp. Not sure if the site block m1 as ping fail. Anyone contact m1 before on similar issue?
Maybe you want to show the IPv4 address of the China site to see if other M1 users have the issue or not.
You can try the following two method to see if you can access the site.
1) change DNS server to Google/Cloudflare public DNS server, like 8.8.8.8 and 1.1.1.1.
https://developers.google.com/speed/public-dns
https://developers.cloudflare.com/1.1.1.1/ip-addresses/
2) use a VPN client, like the free Cloudflare Warp (1.1.1.1 app).
https://one.one.one.one/
007Mi6
Hi, thanks for the info. I just collected my BT10 and doing the setup now for the home network.
hopefully it works well.
29 Dec M1 coming to do the upgrade.
Aladdin Beast
cr0wnclown
Hi all, need some help here.
I'm currently on 1 Gbps with Asus GT-AX6000 contracted until March 2026 @ $33.79/month
There's an offer for me to recontract to 6 Gbps @ $42.90 with router, TP-Link Archer BE805 or Asus RT-BE92U or 10 Gbps @ $34.90.
I'm thinking of getting the 6 Gbps and Asus RT-BE92U and use my existing GT-AX6000 for Wireless AiMesh. But based on my research, GT-AX6000 is Dual-Band and RT-BE92U is Tri-band.
I want to use the Wireless AiMesh because my MBR is having intermittent connection recently and the MBR bathroom's connection is weak. Unfortunately, I did not plan for an ethernet port in my MBR.
Floorplan for reference:
Any advice on if the wireless AiMesh will work and if I should take up the offer? Thank you!
yukita
That is the normal recontract offer for M1 10Gbps plan.
You may want to sign up as new user to enjoy the S$30.90 Christmas Offer, if your contract has expired or close to expire date.
i got home phone number, if were to re-sign up as new user, do you think they allow you to transfer the number over?
ksapple
Question any one on 3-10 gbps de plan manage to get hardware to compliment the speed ah ?
Should be easy if you are willing to pay.
1. 3Gbps plan -- you can use 2.5Gbe capable HW to get about 2.3Gbps wired speed. For example you can use the M1 provided free TP-Link Archer BE230 router and cheap 2.5Gbe USB Ethernet adapter to get above 2Gbps wired speed.
2. 6Gbps plan -- you use 5Gbe capable HW to get above 4Gbps wired speed. You can also use 10Gbe capable HW to get closer to 6Gbps.
HW -- eg, use M1 provided Archer BE805 router and 5Gbe/10Gbe adapters from the following thread. 5Gbe adapter can be pretty cheap.
https://forums.hardwarezone.com.sg/threads/5gbe-and-beyond-ethernet-adapters.7068236/
3. 10Gbps plan -- You can also use 10Gbe capable HW to get about 8Gbps.
HW -- eg, use M1 provided Archer BE805 router and 5Gbe/10Gbe adapters from the following thread. 10Gbe PCIe adapter can be pretty cheap. 10Gbe USB 3.2 adapter is not expensive either if you have USB 3.2 Gen 2x2 20Gbps adapter. 10Gbe USB 4 / TB4 adapter is at about S$100 to S$120 from Taobao.
4. M1 typical wired speed
Typical Broadband Speeds Measurement and Methodologies for Fixed Access (Dated 1 July 2025)​
Fibre Broadband Typical Download Speed Range
Theoretical SpeedTypical Speed Range*
1Gbps912.7 – 961.3Mbps
2.5Gbps1763.2 – 2295.1Mbps
3Gbps2036.8 – 2560.0Mbps
6Gbps2076.9 – 5679.6Mbps
10Gbps2580.2 – 8164.2Mbps
*The Typical Speed Range refers to the range of download speeds that users can experience 80% of the time based on the specific test conditions and parameters stipulated below.
Testing Time Frame: April to June 2025.
zjlim86
I got the asus BE98 on 12.12 sale for around $792. recontract with M1 to 10gbps on boxing day. went online to get 10gbe adapter for around $77. total cost to go for the 10gbps.
Asus80
That is probably a problem.
StarHub kind of allows this based on the reports, not sure about M1.
My uncle M1 fibre from 1Gpbs upgrade to 3Gpbs phone line cannot transfer have to take new Number
If you are willing to pay, it is a very good buy to get Asus ROG GT-BE98, which is top of the line Asus WiFi 7 router and kind of the best consumer WiFi 7 router available in Singapore market.
S$792 seems to be a good price for ROG GT-BE98.
If you are not willing to pay, there are still quite some options for 10Gbe capable WiFi 7 routers and even more options for 2.5Gbe capable WiFi 7 routers.
10Gbe capable routers (wired and wireless) and 10Gbe capable switches, RJ45 version and SFP+ version
https://forums.hardwarezone.com.sg/...and-switch-rj45-version-no-sfp-ports.7072646/
https://forums.hardwarezone.com.sg/...port-switch-and-vq-xgs-pon-onu-stick.7047645/
WiFi 7 routers (10Gbe capable, 5Gbe capable, 2.5Gbe capable)
https://forums.hardwarezone.com.sg/...-7-routers-without-6ghz-band-support.6905228/
5Gbe and 10Gbe network adapters
Network configurations for 3Gbps/5Gbps/6Gbps/10Gbps Fibre Internet
https://forums.hardwarezone.com.sg/...ns-for-3gbps-5gbps-6gbps-10gbps-plan.7073159/
