Network wise pretty similar, so are the outages.
Here are some known difference for you :
Vivifi & Zym doesn't supports VoWifi, Zero1 has previously claimed VoWifi support, but later denies that. User feedback is that it doesn't work, except a single report of it working.
Zym don't have esim so far, zero1 & vivifi has.
Zym requires an app to do any management, zero1 can use app or web, vivifi only web.
Zero1 has least talk time for plans >=$10, Vivifi has more and zym has even more.
Zym requires
IDD add-on plan to call IDD,
Zero1 &
Vivifi is pay per use.
Vivifi supports number port anytime, zero1 submit at application, zym submit at activation.
Vivifi seems to have a reputation to get the name order mix up resulting in porting problems.
Physical sign up : Zero1 at
Harper Point, Vivifi have a
few, zym has
lots.
Zym send bill by 5th/deduct on 10th, zero1 send bill on 6th/deduct on 8th, Vivifi sends ard 25th.
All 3 use calendar month billing cycle.
For the cheapest plan Zero1 is $7.06, Vivifi $7.70, Zym $7.77.
Next ~ $10, Vivifi is $10, Zym & Zero1 is $10.10.
At ~$15, Vivifi & Zero1 is $15, Zym is $15.10.
Zym's $10.10 plan provides free 5G for 180 days, but later Zero1 & Vivifi also extended to 6 months for their $10/10.10 plans.
Vivifi has 2 different $15 plans, most should prefer the more recent "Roam Asia Super 5G" plan. Note the other plan "Roam MY Super" only includes 5G for 12 months. Roam MY Super has been removed from website.
For port in Zym & Vivifi can use with temp no. once activated, Zero1 doesn't provide temp number & needs to wait for port in (including esim, totally no connection before port in is complete, Also sim pick up on Fri-Sun can only activate next business day after 2pm.)
For port out Zym just have to be done by end of month, Vivifi appears to be the same, for Zero1 I can't find anything but there are reports of billing after port out so there might be a notice period there.
For termination Vivifi/Zero1 both ask for 7 day's notice (Zero1 by 3pm), Zym did not specify.
Port back :
Zym - promo doesn't apply for numbers that was with Zym in the past 12 months
Zero1 - if number was with Zero1 in the past 3 Months, there is a one-time registration fee of $10.90 + $5.45 for the cost of the SIM card.
Change of plan :
Vivifi - 5 business days (no longer charge, prorate, lose existing discount),
zero1 - 7 business days ($10.90 for downgrade, prorate, subsequent change a month later),
zym - 5 working days (no longer charge for downgrade, prorate, lose any promotional benefits)
Minimum subscription :
Vivifi - 2 bills (2 months + any prorated part of a month)
Zero1 - 1 month+7 day's notice (b4 3pm) if that exceed the billing cycle, another month will be billed.
Zym - 2 months
