Ethan_
- Sep 27, 2007
Think last time when they do upgrading and improvement will change together right? Maybe the minority haven't kanna upgrading one haven't changed?dats wot moi ish trying to find out, whats the reason for checking but not changing har ?
But hor, even if got do something, need to remember to check their work one, even if its official. Kanna before the forced exercise where they changed the outside meter from analog to digital. End up the worker not sure got certified or not, done a sub-par job. For a long time after that DB kept getting tripped.
Initially thought was inside house old wiring, appliances or DB issue. Got people checked here checked there no issue. At wits end. Almost want to change the whole house wiring for nothing liao. Then the experienced electrician suspect could be outside mainbox issue. Thus asked to call the relevant authority came opened up and checked.
Sure enough one of the switches had burnt mark. Think the finding was the previous worker never done a good job of screwing the wire tight when installing. Not full contact. Thus resulting in overloading of sort at the switch. Lucky never kanna fire. This kind of sub-par work really is very wang-ong to the house owner. Want to complaint also don't know where to complain.
After the changed and reworked liao no issue anymore. So think cannot take authority for granted one. Not everything they do is right. Especially nowadays sub-con out so common. If got issue, it may not be owner issue if cannot find any fault. Need to trace back to their source also.
