- Jul 29, 2003
I see thanks. Next time I pop by maybe I ask alsoJust walk in to change sim, no emails or updates... I just tried ask when I passed by the Zym authorized shop in JEM and they said ok.. less than 5 mins done.
There are 3 celcomDigi network to choose from. You can only log in to one of the CelcomDigi network, another will be end up no signal and another one will be 2g network. Zym only roam on Maxis and one of the CelcomDigi network. Can roam into Umobile but not usable.Just came back from JB, was roaming on ZYM. How come I can’t select other roaming partner? The only option is automatic and auto connect to MY MAXIS, can’t choose digi or anything else also. This is on iPhone 17 Pro with ZYM 5G SA SIM card.
Problem is there is no option for me to choose from leh, only can do automatic .... and only MY MAXISThere are 3 celcomDigi network to choose from. You can only log in to one of the CelcomDigi network, another will be end up no signal and another one will be 2g network. Zym only roam on Maxis and one of the CelcomDigi network. Can roam into Umobile but not usable.
ZYM website did not update anything, still showing maxis and digi ... lolzThere are 3 celcomDigi network to choose from. You can only log in to one of the CelcomDigi network, another will be end up no signal and another one will be 2g network. Zym only roam on Maxis and one of the CelcomDigi network. Can roam into Umobile but not usable.
if choose network manually, no CelcomDigi?Problem is there is no option for me to choose from leh, only can do automatic .... and only MY MAXIS
For m,e Maxis is working fine (default partner)
Digi works fine too i remembered i tried before.
https://zym.sg/preferred-roaming-partners/
Malaysia > Maxis & Digi
hi all, can I check which ISP connection profile do you use?
is it Singtel or Singtel (Postpaid)?
I saw a list of different Singtel profiles but two of them both shows e-ideas for the APN, but for authentication type, one shows CHAP while the other shows PAP.
Yes, I remembered I posted the merger when I was using MAXX, having the same issue with connections.because Celcom merge with Digi, thats why when search the network manually you will see 2 CelcomDigi network, 1 is actually celcom another 1 is Digi, so Zym user can only roam into Digi
5G router (TP-Link NX200)You are using a 4G or 5G router?
Just try the default will do.
If really can not, try PAP first (better compatibility) then CHAP (better security).
https://rublon.com/blog/pap-vs-chap-whats-the-difference/
there was no option to select 'default' (or 'none') for authentication type ... unless I create a new profile and enter the details manually, then I can leave the authentication type as 'none'
anyway, the reason I'm asking is because the network got cut from the router suddenly at random and I'm not sure why.
I had to change to a different Internet Profile to reactivate the network. so there are two options for e-ideas APN: select 'Singtel (Postpaid)' the authentication type is "PAP" but when I select 'Singtel' the authentication is "CHAP"
also, does it matter whether it's IPv4 or IPv6?
IMHO.@keenklee
Please help as well when you get the chance to look at your TP-Link Deco X50-5G settings for the APN and Authentification type for your Singtel heya (now Singtel hi! 4G postpaid plan). Thanks.
IMHO.
NO settings on Deco app and web interface for x50-5g
Can't even choose, everything blank out, only got automatic lol ..if choose network manually, no CelcomDigi?
what phone? is there an toggle to turn off automatic? on iPhones, the network selection list will appear after you toggle off automatic.Can't even choose, everything blank out, only got automatic lol ..
