Anyone here staying in 2 room BTO?
Should we move it to HomeSeekers and HomeMakers?
  • Total voters
    49
  • Poll closed .
Mr.Canberra
I like the design and layout leh, only issue is 4 bus stops from the MRT station. Thats quite far.
Is it Eastcreek @ Canberra? This is at the furthest corner in Canberra.
During late nights can clearly hear "Saving Private Ryan" live sound effects from Simpang forested area! 🤣
flowerpalms
Actually the owner still got do a simple tv cabinet leh with the TV drill and hang on the wall. Mine only get a small cupboard for my TV.
2rm living room alrdy limited space so dont waste money get feature wall. Either mount tv on the wall or buy tv console. If tv console then buy those TV that is non mounting type. Also cheaper
The_King
this 2 rm turn kitchen turned into bedroom (2 rm tele grom)
me guessing ppl dont really cook, or just boil and reheat food
The_King
me plan to redo my kitchen. this time with real SS 304 and no wood on the kitchen cab (some cheaper SS kitchen cab add wood below the tabletop for support)
option A
look nice but the leg gap too narrow, prefer to be at least 18cm gap, so easier to mop
or option B:
this one alu, i think this one suit me
yokine3a
option A
or option B:
SS cheaper or aluminium cheaper? Assuming you are engaging local supplier.
The_King
it seem like aluminum is cheaper by A star, my guess it is just a normal kitchen cabinet, but promo as aluminium kitchen cause the plywood replace by aluminium
the rest of the item same as you could do a kitchen
ss 304 is depend, if you get those modular 1 pc, it should be the cheapest while if you customizer a lot ss304 will becum expensive
modular 1 pc of say 2.1m by 60cm by 90cm,2yr ago quote 3.5k to 6.5k. there a 2 over 8k, so ignore those. and song cho ignore as it 20 to 40k
