Try running 30s/km slower than the pace you usually run and see if your HR is lower.
I don't know whether there is such a test but I want to try the running economy test since I think it will be a better predictor of marathon fitness. Having never done the marathon before, it might be able to shed some light into what pace I can aim for without blowing up.
that will be ur lactate threshold test. that's more relevant. It measures your vt1 and vt2, from there you know your zones, ur LT, then u can train accordingly
ok i share my old (2022) LT Test results here since the data is irrelevant:
so this is what a LT test will look like, at every interval u run (+1kph every minute), they prick your finger to analyze the lactate (lactic acid) level that is accumulating in your blood. So in the results above, you see those red dots? That correlates with the LHS y-axis, so u can see all the way up till 11.75km/h, i was below 1.0mmol/L of lactate, meaning I'm using my aerobic system to run (primarily fat-burning, easy running, conversational pace), but after that, it starts to climb rapidly. Between the 3rd from the last and last pt, I was using primarily my anaerobic engine, so burning alot more carbs than fats. And at precisely 13.4km/h and above, that's my lactate threshold, meaning my body can't clear the lactate out of my muscles fast enough, you can literally feel this, this is what you'd describe as the "burn" in your muscles when you go really fast.
From this, you have many pts (speed zones) and your heart rate to the RHS y-axis, you can calculate your five training zones accurately because you now have solid, reliable data. Then when you apply this when you run, you know exactly what pace you will maintain in your Zone 2, and what pace is your LT when you wanna do your tempo runs, or 4x4 intervals.
hope this helps!
