yukita
I nominate montech century 2:
https://www.montechpc.com/century-ii-850w
Dimensions (L*W*H) - 140*150*86mm
Alternatively, you can consider the FSP Vita GM. I'm using it with my Jonsbo D32 pro and it fits without any issue. I'm also using it with a 9070xt sapphire pulse.
Main advantage over superflower is that they offer 10 years warranty.
Montech looks good as its smaller size. for FSP who is the distro?
iceblendedchoc
Zotac card is 303.5mm x 115.8mm x 55.7mm
I think both of you are right, when i look at Lian Li, I look at side mount PSU config, this cause the GPU length support only 258mm. but if i mount front side. it support 334mm.
For CH260, already mention max PSU is 150. because its side mounted, i think this one no hope unless change PSU.
For Jonsbo, it is stated:
ATX PS2 PSU Clearance:
• When the GPU is installed in the first PCI-E slot of the chassis, the maximum length of the power supply is 150mm, and the recommended length is ≤140mm
Can fit in ,my rog psu was longer
Bardiel
ch 260/270 i can only say i fit a 150mm psu with the biggest card xfx mercury 9070xt was very tight. so 160mm might need see how flexible the cable is liao.
currently fixing a d32 pro with cooler master mwe gold 850. 150mm long but i see got ample space to fit 160mm.
i see can fix up by today or not as in need sit in the gpu and see if got amppel space to sit 160
-Synchronicity-
I doubt got space for 160. I'm using 150 right now and the cables are already a tight squeeze. 160, you probably run the risk of the cables being damaged.
Bardiel
@yukita D32 pro here. if u look at the psu end i think 160mm can fit as the 150 here got space. same gpu. the metal almost touching the gpu is the cover to cover the psu.
yukita
this one consider low rgb. did some rgb pc basically at room no need on light. disco disco
i will have headache by having RGB. my current pc is under desk, so its still okay. if on the desk, all off.
by the way talking about RGB, i wonder if we can turn off RGB on the RAM? sorry never have RGB memory before. the spare i have now is RGB unit as i sold my old Crucial pro.
Bardiel
Defintely can turn off.
Dranyeros
Hi all,
I'm choosing between 2 invaderpc specs just for normal gaming (Diablo 2 Resurrected, Diablo 4, maybe some WoW), and general use (e.g., watching YouTube, some Excel/Word/PowerPoint). Ok to play with 1080p, but would be great if these work for entry-level 1440p too.
I can't post links, so copy pasting the specs below.
Master M07Master M12
AMD RYZEN 7 7700 3.8GHz 8CORE/16THREAD
ASUS TUF GAMING B850M-PLUS WIFI7 THERMALRIGHT ASSASSIN X 120 R SE ARGB
CRUCIAL DDR5 PRO BLACK 6400MT/s 32GB(16GBx2) CL32
ASUS DUAL GeForce RTX™ 5060 O8G TWIN FAN OC
KIOXIA EXCERIA BASIC NVMe R7200 W6500 PCIe 1TBSILVERSTONE ATTIS 650R-650W 80+ V1.0 ATX3.1
DARKFLASH DB330M M-ATX BLACK TG
3 X 120MM ARGB FANS
HIGH-SPEED AX WIRELESS AND BT | WIFI 7* + BT 5.4*
WINDOWS 11 HOME UN-ACTIVATED
INTEL CORE ULTRA 5 225F 2.7GHz 6+4CORE/10THREAD
MSI B860M GAMING PLUS WIFI
CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36
MSI GeForce RTX™ 5060Ti 16GB SHADOW 2X
MSI PAG PANO M110A M-ATX CASE BLACK
3 X 120MM RGB FANS
S$1,695S$1,809
Any pros and cons between the 2, or what would be your recommendation? If there are alternative more value-for-money specs, do also let me know. Also great if anyone can let me know if there are any easy upgrades that I can make on any components. Thanks!
networked
Hi all,
3 X 120MM ARGB FANS
3 X 120MM RGB FANS
S$1,695S$1,809
invader pcs are always quite balanced customised. go for the higher 16gb gpu and upgrade your psu.
NightRaven49
3 X 120MM ARGB FANS
3 X 120MM RGB FANS
S$1,695S$1,809
the games u mentioned u will be playing are not super difficult to run, either of these rigs will work fine and will easily run them at 1440p high-ultra. out of these 2, the 5060ti 16gb build would be better value as it's only a $100 top up (<7% premium) for a ~15% stronger gpu with double with the vram. that said,
there is a 7500f + 9060xt 16gb pc they are offering for $10 less than the 5060 build above. the 9060xt is very comparable to the 5060ti performance wise and still offers the 16gb vram capacity which will help in keeping it usable for longer. the 7500f and 7700 are also quite comparable in gaming while being a tier faster than the 225f in cpu limited gaming.
invader should be able to help u upgrade almost anything on their checkout page other than ram and ssd (for unfortunate reasons), but even those are simple enough to diy. u can consider psu upgrade like networked mentioned, something like the silverstone et750g would be ok for a slightly better quality unit but not strictly necessary given the low overall power consumption.
kinda depressing to see these used to cost a lot closer to $1k last year though :frown:
Dranyeros
Thanks all for your responses!
Does this mean the 7500f+9060xt may be the best option out of the 3? Or is the 225f+5060ti still better?
Yea, I know they give upgrade options, but the difficulty is that I don't know whether a particular component is better or not. 😅
