Yeah, i think just gotta try out various options. So can just try less reps, more quality.
In fact right now if you feel that you are still not there yet, try out 3 reps......max out 4. After a month or, then add 1 more rep....then another month another rep, till max of 6 or even till 8 if you enjoy it. Solid focus quality and progressive loading this way. Also, in between needs to be 3-4m recovery, so go play mobile TB app or something lol.
It's also something to be enjoyed, i am sure you like speed as well (who doesn't), so it's gotta be 100%, in minute doses so as to keep the speed maxxed out.
Really no harm to try and see what is best, you know your body best.
eg side story abt trying various options out :
For my pull ups, im also trying out more sets and less rest in between. Right now is 72h recovery between sets as usual (do till somewhat past failure, next 12-24hrs sure got a bit of DOMS). So after work and during lunch, i will just run and route a wee bit farther to my home's fitness corner and hoot out 1 set of approx 6, hollow body pull ups solid form but not to failure....then do some jumping reps.
Then the 72-96hrs workout i will hoot till failure or even past it (I like to do till "max", then shake it out 5-8 seconds, then hoot again, then shake, then hoot....usually 3 times shd do it, to flush the lactate out).
If that works out then i will also do for my dips.
Really, the only way to confirm all the various YT vids is to try out all the various patterns out yourself and then only will you know which works best.
Just came across this recent vid, so decide to change a bit and try out
