SET ST536v6 to bridge mode
celeron85
Hi all,
I just got my router working with the modem.
many tks to Diavonex for sending me the screenshots and starting this thread.
Just something that I would like to share:
1. when entering your userid at your router page, rmb to add the @singnet
2. You need to wait for the wizard to restart your com for you when you are installing the residental cd
3. Password for your modem is the serial no and user id is Administrator
just follow the steps listed by Diavonex and you will be fine (hopefully). =)
if nothing goes wrong, you can complete the setup in 30 mins
jycaisg
Ha , i also get this problem . it is easy . user: Administrator password: your st536 sn
mamboberg
well try all the method shown here. Bridge my modem using the resident cd. But i cant seem to connect to internet at all. My modem the 2nd LED keep on blinking. The 1st and 3rd LED are on and the 4th not on at all.. anyone can help?
mamboberg
ok i just called linksys helpdesk
My setting is change as follow in my router
Ip address: 192.168.2.1 and im using auto config -DHCP instead of PPPoE but im able to connect online even though i'm using DHCP. Is PPPoE necesssary then?
tlkchew
Geeze, i just spoke with the singnet support for 1 hour asking them to find out the password for the ST536V6 Nobody in the entire singnet support know what it is!??!!! omg! keep asking me to contact thomson. Push away. damn sux man they provide the modem, they should at least know.
HWZ still rox...
KT1855
HWZ still rox...
i get the same problem too..
anyone knows whats the password? i tried admin, administrator, blank, everything...
liangtam
Administrator <blank>
Administrator <s/n>
Call Thos if still cant
Diavonex
If you still have problem, try this:
1. Connect ST536v6 to router's WAN port
2. Connect computer to router's LAN port
3. Set PPPoE (username and password) on router
4. Hard reset the ST536v6 for 10 to 12 seconds (use paper clip to poke hole behind ST536v6)
5. Surf the internet
Note: I you still can't connect, hard reset the ST536v6 a few more times.
KT1855
thank you Diavonex and Liangtam..
you guys are a great help.
i shall try that.
KT1855
i called Thos solutions...
for the benefit of others...
it is Administrator
password is your serial no.
Caps sensitive.
My Wifi is now working, thanks again to esp Diavonex and Liangtam for their inputs.
zheyan
thanks to those who contributed.. heh. solve my prob too!
in case still got ppl who still dunno..
for the modem,
username: Administrator
password: <serial no under d modem>
Shu
thanks for the instructions. WIshed I had found it 2 hours earlier.
Perhaps you could edit the first msg to let everyone know the user-id and password are "Administrator" and your modem's S/N respectively. I'm sure I'm not the only one who got stuck at the login step!
