learning japanese
ahmahippo
cool :D
ok thanks.
but learning them is one thing but i got a problem on how to write them.
any place where i could get or print and write each of them on how it should write
PingJun
うえださんんは、つかれて ____________ ように ねて いる。
1。 しに 2。しね 3。しねば 4。 しんだ
This question has appeared in Yr 2002 JLPT 3 Grammar Section.
Just now in class, the sensei has explained this question and how to get the answer [4]. However, many of my classmates were still discussing & asked sensei how come the answer is 4.
I think they might not fully understand this question. I myself also take some time to think about it very carefully before deciding the answer to be 4. Thus, I think it might be a good idea to discuss this question.
PingJun
cool :D
ok thanks.
Why don't you get a Kanji Dictionary? Kinokuniya do sell.
I am going to get one as well very soon.
Niaoson
or you can use the ようas your clue. no other option can fit in and still be grammatically correct
Niaoson
The hint here is ねている
i disagree. ねているdoesn't tell u the answer because the options are all similar but in different forms. ねているwill be the hint if the options are
- しんだ (死んだ)
- たべた (食べた)
- のんだ (飲んだ)
- よんだ (読んだ)
because the only logical one is sleeping like u're dead. you can't sleep like u ate, drank or read, right?
PingJun
According to my grammar notes here, it states that
PF [な / の] よう だ
PF [な / の] よう な 名词
PF [な / の] よう に ~
Does this mean the question actually fits into this grammar?
P.S. PF = Plain Form
Niaoson
sorry i dun really understand ur question PingJun :s22: but if you're asking whether the grammar structure they're testing is the one u posted then the answer is yes. more specifically, it's the third one
PingJun
Yup, this is what I am trying to ask.
dimitri_can
depends on how u see it...
That's my way of seeing it... -__-"
My way of learning Japanese might be different from ur way of learning japanese, right?
ahmahippo
Get a good electronic dictionary that will show you how to write the kanji.
wow... it must be ex right? anyway, sg never sell them?
err... maybe when u bought it, let me know how much it cost? :D
for writing hiragana and katakana, is there any place able us to print them and try to write them the correct way?
fox1
PF [な / の] よう だ
PF [な / の] よう な 名词
PF [な / の] よう に ~
The plain form is しんだ then. Plain past tense.
The so called hint here is つかれて (as he is tired), but not relevant.
It does help you to decide that if you are tired, you will sleep like you died (past tense).
しに - masu stem
しね - imperative
しねば - conditional
しんだ - past
fox1
There is a place called, internet. You can find hiragana and katakana charts. Hehe :D
PF [な / の] よう だ
PF [な / の] よう な 名词
PF [な / の] よう に ~
Eh not sure if this is what you r asking but
Verb plain form + よう (or verb past tense)
Noun + の + よう
な形容詞 + な + よう
い形容詞 + よう
Was wondering if its the past tense or present tense....
When you add に to よう, you would have changed it into an adverb. (describes the verb)
あの。。。質問があります。
1)「もう起きました」と「もう起きていました」の違いは何ですか?
2) 「ドアに鍵をかける」
   「ドアの鍵をかける」
   「ドアに鍵がかかる」
   「ドアの鍵がかかる」
「に」も「の」も使うのを間違えないですか?
