iRobot Scooba experience
hanneng
anyone used this M-488 before?
look like this can do simple floor sweeping ..
mosmos
High Honorary Member
wootoff now, those who want to buy cheap roomba or scooba can monitor this website. :o
roomba 535 already soldout and over.
www.woot.com
edhazelk
I saw it at tampines..wanted to buy it but after "playing" with it....really no pt buying....very not intelligent.
Always stuck at the corner n wont move...
Ms Prettycloud
Anyone has an US adapter for Roomba 530 for sale???
or anyone can repair it??
My mil accidently set the stepdown transformer to input 110watt and think adapter is burnt..
thanks
webstop
Hope somebody can give some hint on what's wrong with my iRobot Roomba 550.
I bought a Newstar 100W step-down transformer. Initially it charged fine, but stop after half an hour. No light at transformer nor adaptor.
Then I bought a Newstar 80W step-down transformer. No light on adapter and no charging at all. Got red light on transformer, and a sizzling sound for a while, then the transfomer explode, with light, smoke and loud sound.
Is the adapter spoilt? Or I need to get a better transformer? Thanks.
mosmos
For transformer, did you put the switch at the correct voltage? :s11:
input from supply mains should be 220v and output to your roomba power adapter should be 110v. :o
webstop
I opened it up to look inside (and it's hot for a few seconds of work), I think most part has melted away. There is even black substance that spills over through closing.
is there a fuse in it ?
my fuse broke after using for a few hours.. then replace it and it last until today.. around 2yrs..
Jubooo
I can modify your PSU for you. drop me an sms @ 81254240 if you are interested.
mutya927
hi mosmos, thanks, so lighthouse is much better than virtual wall?
i'm also considering at ebay for brand new roomba 550 for ~S$420 with direct shipping to SG..worth it?
mosmos
Yah much better if you need this function to clean each room properly.
For my roomba 400 series, I just let it roam around w/o any virtual wall. No problem with that, still can vacuum the rooms quite cleanly :o
sgd420 is quite a good price.
