Kurzweil KS-40A speakers good?
silx1980
Managed to pair these with my sub from Creative I-trigue 3400. Sound and bass is now good and powerful but need to adjust the left right balance as the left speaker tends to be softer. Any method of correcting this off balance?
AlvinDj
Where and what's the best price we can get for this pair of speakers now.. ?
Really wanna audition how good it is..
boxsurat
you can go to city music to audit. however, they don't have special room to audit. you will audit together with other people who audit the music instrument.
boxsurat
does it mean you connect both speaker to sub? if you connect both speaker to sub, see if there is balance button on the sub.
silx1980
Nope, no balance on the sub. Now using the sound card software to tweak left to +4 gain more than the right. Just worried it might damage the speakers if I do this. :o
wwenze
You're not supposed to connect the RCA out from your Creative subwoofer to the RCA-in of the Kurzweil or anything other than the passive speakers or satellites of the woofer.
silx1980
Oh damn......was worried about this. But when I tried to connect the KS to the soundcard and the sub to the c/sub out of the sound card, the sub doesn't work. Any idea how I can get the KS to work with a sub in this case? Using a usb X-FI 5.1.
silx1980
Because under City Music's site, it is stated as OOS
Their new stock just came in but I guess due to too many pre-order stocks ran out fast. It will be much easier to just pre-order the speakers from them, put a small deposit then wait for their call when stocks come in.
wwenze
The get the c/sub out to work, the soundcard must be set to 5.1 mode.
Alternatively, set the soundcard to 4.0 (quadraphonic) and use the rear out.
Or use this, less than 5 bucks at electronics/diy store.
boxsurat
try to set the speaker setting as 2.1.
silx1980
Ok found the solution, was my driver causing the c/sub not to work. Dunno why also, anyway after update to the latest drivers and reboot comp it worked! Noob here at audio stuff so paiseh if pissed off any gurus here k. :o
So setup as follows:
Configure sound card to work in 5.1 mode. Reboot Comp.
sound card Left Right channels -> KS 40
sound card c/sub -> woofer
tjkjean
Hi all, me looking at letting go this pair of speaker bought in feb (without box but with receipt).
Pm me if keen. Thanks
