Samsung Galaxy Ace S5830
glenchen68
ya.. anyone know how to edit/save the picture in pc ? i tried to rotate the picture & save also cannot...
have you tried dismounting the MSD card and copy/paste into PC? it's in the DCIM folder, under Camera
.... or if you have already installed Kies, plug phone using the supplied USB cable, after successful detection you will see your MSD card storage at "Basic Information" tab, click on "View in Explorer", double-click "DCIM" folder followed by "Camera", choose and right click "edit" your pic....
it will open with your default Paint s/w, choose "save as" to copy to PC
Swiftz
Hi all, I just got the fone yestd n realised it can't play 720p mp4 movies.
I called Samsung and they say Ace can only support mp4 H.264 & H.263 and 3GP files only. So my questions are
1. Any player in Market App that I can install which can play 720p mp4 movies? Tried moboplayer, mVideoPlayer & RealPlayer Beta already, still can't.
2. Or is it becos Ace display size is 320 x 480 pixels, so can't play 720p?
Thanks in advance.
vectorguru
Thanks in advance.
omg...u made a really bad choice....this phone really SUCKS at multimedia and gaming...can't watch online video....can't play good quality games.....i regret getting this phone and should have stick with iPhone4...then again it's a cheap phone with cheap standard and quality...live with it loh :)
kennyboy
Thanks in advance.
1) Low end phone, slow processor, don't expect too much.
2) Nothing to do with screen resolution.
junxiang94
i'm having a hard time choosing between samsung galaxy sl i9003 and ace. which one do you guys recommend? and battery wise the ace will last longer right?
flame2000
Battery life is terrible for the ACE as reported in other forums. Lasting only a day with average use. Wifi off, brightness at lowest. :s27:
surefire888
The galaxy sl is a good value for money buy with a nice perfectly-sized screen. If u r looking for just a basic android phone, u may want to look at the lg optimus one instead which has got gd reviews n is at least $100 cheaper (only $312 at mustafa). Was reported that the optimus will be getting 2.3 while imo this is highly unlikely for the Ace
Fyi, u can compare the 2 samsung phones at vivo - i found that my ip cam displayed better on the sl. Also connected to my bluetooth gps easier while needing a few tries on the ace. Ultimately, it was the size of the screen that clinched it for me. 4" is the minimum for comfortable web browsing. All depends on yr intended usage. In my case, i have a separate nokia for voice calls n sms n just use the sl for gps, multimedia n web so screen size is imp
maxcava19
allo all.i juz got a galaxy ace,do u guys get problem with ringtone n sms tone? after a while it auto change to default tone?
2nd while plugging to charging,the phone screen jammed and need to remove and put in charger to reset? intermintend problem one.
vectorguru
anyone got this error when connected to Kies?
can't update to latest firmware....
Mine set is local singtel...2.2.1
all local set CANNOT update to 2.3!!!!!!
see pic
kennyboy
see pic
And what makes you think 2.3 is released already?
daniel_83
so issit normal to have both BLACK and WHITE back covers for buying the WHITE set??
tnatna
if you are ok with your camera not having flash and your phone cost 200 bucks more, then you shd choose SL. personally, if i have to choose value for money, i will buy ace. if i wanna big screen, i will buy second hand galaxy s, not SL.
surefire888
in my case, i was looking at recontract prices and the SL was only $150 more. Also, the discount on the SL vs the market price is larger than for the Ace.
As for the Galaxy S, i think it is way over-priced merely bec of the super-amoled screen. For just a little more, you can now get the dual-core LG Optimus 2X.
