lightchaser
- Sep 26, 2001
i cant use ph to download as i dun have dataplan
You using prepaid card?
You can download them using Wifi as well.hi,
just gotten a samsung ace and dunno how to download apps to phoneI dun have a dataplan and can't copy the app that i downloaded on my PC to the phone as it is not supported by Kies. Help
Use the phone's app market to download. alternatively, go to Settings-Applications and make sure "Unknown Sources" is checked.
i cant download as I dun have any internet access on my phone
hi, does anyone know how to enable chinese characters when writing SMS or Memo? i've enabled chinese keyboard under Settings but it doesn't appear.
hi,
can ask the experts here whether a 200mb dataplan is good enuff for normal surfing and download of the odd apps ? TIA![]()
hi,
can i use skype on this![]()
Have flashes with Gingerbread 2.3.4, European version.
As reported earlier by someone on this forum, laggy with lock screen taking about 1 sec to respond.
But the "sleep of death" or "hang" or "press power 15 sec to reboot" bug still exists leh.
Hi
I am new and I have this problem...I am unable to load all my app icon and I have this message "Sorry!.....The application samsung home (process.com.sec.android.app.twlauncher) has stopped unexpectedly. Please try again"....I have tried on-off...took the battery out and re-installed..on again...but the same eror message keep coming out....anyone know what is the problem?
Huh... SoD still exists in Gingerbread ah...? Damn sian.![]()
Barely enuff. 1gb should be safer if u dont want to get heart attack from the bill shock.
gone... have to do hard reset..
i tried some ways others have mentioned before but all failed.. good luck.. everything gone..
